Vibration on braking when some heat in the brakes
Goubo1 Jun 6, 2018
  1. Goubo1
    Goubo1 Well-Known Member
    1,205
    485
    Had the car out over the weekend and noticed when there is a bit of heat in the brakes I get a fair bit of vibration coming through the steering wheel
    Brake set up is 18z calipers mtec 2 piece discs with stock textar pads and hel lines
    From memory the discs haven’t had much heavy use where they would have possibly been warped
    There was once when I was away at work the car was sat for over a month and when I went to use it the pads were stuck on rather hard took some effort to free them off and with a loud bang could this have caused anything??
    My mate suggested getting the discs off and check for corrosion between the hub and bell of the disc.Anyone else got any ideas ??
  2. Avatar
    Google AdSense Advertisement
  3. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    2,777
    747
    Might be worth checking the disc is tight if it’s 2 piece discs
  4. Goubo1
    1,205
    485
    The bolts were all checked prior to fitting with a torque
  5. S3AMJ
    S3AMJ OEM+ Team Brilliant Black Audi S3
    1,360
    378
    Sounds like your discs have warped.
    Might be worth getting them checked like in this video, at least that’ll eliminate that possibility mate
  6. <tuffty/>
    23,483
    5,041
    Check torque of wheel bolts and bell bolts... worth rechecking regardless of them being fitted correctly before
    Goubo1 likes this.
