If you did not know about your vehicles diagnostic firewall then I would suggest holding off on any more serious “coding” using VCP. Take some time to read up on the application you have purchased else you might do some serious damage.
Thanks for the advice
I was aware of the potential to screw something up with 1 wrong move when coding so I went slow and methodical.
Strange thing is, I can't find much info on this diagnostic firewall except in the link I mentioned - almost like you have to be in a
club to know about it. If you look at any write-ups or photos, the bonnet is never up. The link I shared is from 2019 so it appears to be reasonably new, correct me if I'm wrong? I even spoke with the retailer and they didn't mention it, although they seemed pretty useless...
The write-ups are poor or non-existent for VCP, and the forum is locked down and I'm still awaiting access. I've documented any change I've made to the car and I have an auto-scan before I changed anything so it can be reverted back to stock if needed.
Anyway, I got:
- Needle sweep
- Lane assist
- Chirp on unlocking/locking
- Tailgate closing sound removal
- Start/stop disabled
- Map in MMI
- TSR.
Nearly all could be done with VCDS or OdbEleven, however, the reason behind getting VCP was for TSR.
I'd already spent a few days reading up and saving links to educate myself but it's not the same as diving right in. Some differed slightly so it took some time to review.
After some failed attempts with getting no ECU response, seed failed and pre-programming conditions, leading to my earlier post and further research, I got the bonnet up, checked camera software version and with some reading on
here about which file to use, I was successfully flashing with no errors and TSR popped up easily.
So far, all is working and I have no dashboard errors. Tomorrow I'm going to check for any errors flagged up and then I'm pretty much happy.
I can share my links and changes if people want (just ask) but you must do your own research and remember that the coding I share is a collection from the internet.
Edit: This appears useful too, even if for VCDS:
https://www.audi-sport.net/xf/threa...-up-your-vehicle-using-ross-tech-vcds.324907/
