VCDS tweaks - couple of coding questions
Djwoody
Middlesbrough
Hi.
I own an A4 B8 2008 model and have just had a few VCDS tweaks added.
There are a couple more I would like to add but the guy who programmed the others couldn't find them.
Does anyone have the coding for:
1. Beep when locking/unlocking
2. Changing the Service intervals - I would like the normal service to be on an annual basis (say 12000miles or 365 days) and also Oil change to be every 6 months (6000miles or 182 days)
Many thanks in advance
Chris
I can only help with 1. I tried it on my B8 and when enable it and lock the car sitting inside you can hear a little beep. That's it. I haven't been able to find anything better. Had it on my B6 and really miss it on this car.
So there is no alarm 'chirp'?
I had it enabled on my 58 reg A3, thought you'd be able to do it on the A4 as well.
I found this one also, wonder if this will work. Although, it's not an alarm chirp.
Enable Horn confirmation on locking
[46 – Cent. Convenience.] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 2 - Check the box or change (Bit 2 Set to 1)
