VCDS Scan after ABS / ESP fault last night
ScottyP45
Well-Known Member
Lads, anyone who is VERY familiar with 8P coding want to look through the following autoscan and tell me if they see any long (or short) coding errors - I know now I have a mechanical fault on the rear right ABS sensor but there are a few oddballs that aren't clear like CAN bus single wire (comfort module) etc., they may be genuine errors or it could be someone before me has had a go at fiddling with codings...I think the steering assist code is related to the ABS issue and the steering wheel is squint (not centered) but that will be fixed tomorrow along with the ABS sensor. Any well-informed thoughts welcome!
Friday,01,February,2019,13:32:21:49450
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 77
VIN: WAUZZZ8P29A092817 Mileage: 154590km-96057miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 997 016 R HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 0279
Revision: 13H01--- Serial number: AUX7Z0HDFN40QU
Coding: 0000072
Shop #: WSC 84224 794 674630
VCID: 41892F621848E04AEF-8014
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 13424012092B00FCC81302E5902000823800
Shop #: WSC 06314 000 00000
VCID: 74E7B6B6D77A05E2B4-8020
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 251
Mileage: 154539 km
Time Indication: 0
Date: 2019.01.31
Time: 18:18:50
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 83
Count: 50703
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000151 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72EBB0AE6D6E0BD2A6-8026
1 Fault Found:
01592 - Air Quality Sensor (G238)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 9
Reset counter: 248
Mileage: 153978 km
Time Indication: 0
Date: 2017.01.01
Time: 07:51:28
Freeze Frame:
Temperature: 7.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009189857
Coding: 11A82F07A0141380EF00001C4F00000000084E0564010003002000000000
Shop #: WSC 06314 000 08192
VCID: 489F32463B72D10228-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 49993742E878280A37-801C
Crash sensor for side airbag: driver side:
Serial number: 34928RB4000048AF18C/
Crash sensor for side airbag: front passenger side:
Serial number: 35028RB4000048AA245H
Crash sensor for side airbag: rear: driver side:
Serial number: 35128RB4000048AF18DY
Crash sensor for side airbag: rear: passenger side:
Serial number: 35228RB4000048AFD82-
Crash sensor for front airbag: driver side:
Serial number: 35547RB400004A4CAAD0
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400004A4C99C+
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 224DH007012006
Coding: 0004428
Shop #: WSC 12345 123 12345
VCID: 397947827098B88AA7-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08B270EEA
Coding: E9801F06000602000101
VCID: 377D41BA468CAEFA51-8062
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 8
Reset counter: 253
Mileage: 154539 km
Time Indication: 0
Date: 2019.01.31
Time: 18:14:19
Address 25: Immobilizer Labels: xxxxxxxxxxxxxxx
Part No SW: 8P0 xxxxxxxxxx HW: 8P0 xxxxxxxx
Component: KOMBIINSTR. VDO H19 xxxxx
Revision: D0Hxxxxx Serial number: AUXxxxxxxxxxxx
VCID: xxxxxxxxxxxxxxxxxx
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 4385256A0254F25AFD-8016
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 233 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C576ED68FCA1D222C-8078
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 48
Mileage: 154569 km
Time Indication: 0
Date: 2019.02.01
Time: 07:49:43
Freeze Frame:
Voltage: 13.38 V
DU
Temperature: 6.0°C
RPM: 1510 /min
Speed: 24.0 km/h
Speed: 24.0 km/h
Count: 0
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000564
VCID: 44872676075AF562C4-8010
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3H3499574
Coding: 0730201
VCID: 3F8D299A6EBC96BA99-806A
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005057596
Coding: 0001222
VCID: 46833C7E3166C772DA-8012
End-------------------------(Elapsed Time: 01:46)--------------------------
Matt268uk
A3 Sportback
I've had that same single wire fault on my car for a couple of years now. I changed the loom in the door where i thought the fault was but with no change. My car shows no signs of a problem so am waiting to eventually see if the second wire breaks and something stops working to point me in the direction of a cure.
ScottyP45
Well-Known Member
@Matt268uk Yeah I'm about where you are on that one, but the ABS ESP fault which crops up on the Power Steering block as well, is the main issue. I expect to need a hub on the back and probably both rears to be sure as I've seen people say they did the side indicated by the diag software but the other side failed shortly after. Hubs are fairly cheap. Hoping that will clear the ABS fault on the steering assistance address.
The car drives absolutely spot on and everything works.
ScottyP45
Well-Known Member
http://wiki.ross-tech.com/wiki/index.php/00470.
Clear all faults and see what comes back
Cheers Chic, yeah I cleared them and these are solid. Oddly it had entries going back to 2015 for the same fails and the OBD connector is dodgy, have to twist the plug to the right till the LED comes on, to communicate...so no idea how that garage managed to scan it (didn't is my guess) as they claimed to have used a snap on tool and e everything was "ok"...yeah right
Also the undertray where the connector is, has been removed before and isn't tightened properly....have to take a look at that in daylight. I cleared everything yesterday and these codes came straight back up.
abmat
Well-Known Member
That fault has been present for the last 3 years then.
I think in that area would be a good place to start.
ScottyP45
Well-Known Member
Yeah it's going into my local trusted garage on Monday, not the one I bought it from, to have the ABS fixed and the steering alignment done. After that I'll clear the codes and see if it settles. I have a six month Driveline Plus warranty from ScotSure so will claim on that if it needs anything done, which it will. I could fix it myself but I'm getting to the age that laying under a car in winter is no fun! Tweaks and mods now that's different...
ScottyP45
Well-Known Member
So forgot to update on this one for anybody having the same issue. The right rear (G44) sensor was rubbing on the bearing housing so both were replaced. £70 for parts and £110 for labour which included steering alignment. Now perfect. I used vcds to clear down the stored codes and all gone (apart from the air quality sensors and canbus single wire faults which are unrelated and remain)
All of the other fault codes were due to the damaged sensor and went away when fixed and cleared.
ScottyP45
Well-Known Member
Update, a few days later the other side began faulting so back to the garage....this time the nearside ABS hub had a chunk out of it! So now both sides done, sweet. Back to normal with no infernal beeping.
The moral of the story is like most things wheel related.....do things in pairs the first time!
