VCDS Radio Coding
Eggyevo
Please Can anyone help with the VCDS coding required when retrofitting the RNS E
from a BNS 5.0
S3 8P
Best to give more info off what you have in the car as this is needed for coding , ie , Bluetooth, cruise control, mfsw, etc
When i got the car it had a alpine system with a non mfsw then I replaced the steering wheel with a flat bottom mfsw and the buttons on the wheel don't work
Car has no Cruise Control no Cd Changer, no Telephone and I'm not sure if it's got Bluetooth
I no it's got full Bose
Can you do a screen shot off your coding helper in module 37 in your Vcd's then I will get an idea which is in your pop up , should look similar to mine, If it is exactly like mine try this , then if you read pop up you will see how I got this code and if it is not correct tweak it 0219155
I've seen that I'm just getting confused in which numbers to put in lol
Can get confusing more so the wording but as you haven"t got a lot off extras it should be simple enough , let me know how you get on. To check see if you have Bluetooth , put it phone to BT and scan to see if it finds it unit
Ok thanks
I will give it ago later and let you know thanks for your help mate
7K
17
Abi
10
9
