  2. Dismiss Notice
VCDS Modifications
davidbir Sep 21, 2016
  1. vibeup
    vibeup Registered User
    52
    This...
    So close but so far
  2. Avatar
    snack-media
    Advertisement
  3. Daggerit
    Daggerit Registered User
    3,194
    1,633
    The only thing I can think of is that there's a region specific part to it? That's a different message than I get on my car if it decides it can't read a traffic sign (which has it from factory), so maybe it's looking for a US style sign or something? Just a thought and I've done no coding so don't know if that's even an option within it...
  4. Happy Grumpz
    Happy Grumpz Well-Known Member Silver Supporter
    568
    706
    93
    You’s have been for a drive right? That appears on mine until the camera either detects a sign or the speed limit from the maps takes over.
  5. vibeup
    52
    I made more than 1k km and it doesn’t work.
  6. cuke2u
    cuke2u Well-Known Member
    13,060
    5,281
    Does it require navigation plus as Kufatec seem to imply?
    • only for vehicles with PR-No .: QK1 and 9S7, 9S8
    • For vehicles with PR No .: 9S5 no display in FIS possible
    • for vehicles without navigation plus (PR no .: 7UG) only limited operation possible. Due to the lack of Navidaten be partially z. B. no place signs and tempo zones recognized
    HazzyDayz state this:
    Please note: Only Suitable for models with PR-QK1 Driver Assist Camera and Colour DIS.
    Happy Grumpz likes this.
  7. Johnny_cass
    Johnny_cass Registered User
    49
    Is there anyway to disable no sim card warning on starting maps.
    Sent from my SM-G950F using Tapatalk
  8. Paul070977
    Paul070977 Registered User
    Hi,
    I have followed all the active lane assist instructions and i get a fault with audi pre sense when i select
    • Set Heading Control Config to 'heading_control
    I have left the car overnight and i still get an active lane assist fault
    And audi pre sense fault when i turn the ignition on.
    I have followed the steps multiple times but still get the errors.
    The mmi has been reset and active lane assist is shown in mmi but is greyed out.
    I have a fault code C10ACF2 in steering
    And fault code U101400 control module incorrectly coded
    Any ideas or help appreciated.
  9. cuke2u
    13,060
    5,281
    I suggest you PM DJAlix...
  10. vibeup
    52
    I have all of them:
    QK1 camera
    9S8 Multi-functional display / on-board computer "FPK" (active info display)
  11. RJ-8V
    RJ-8V Registered User
    749
    187
    43
    @vibeup did you flash the camera for traffic sign display?
    @Paul070977 did you coded EFP and APS?
  12. Avatar
    snack-media
    Advertisement
  13. vibeup
    52
    Can i do that with vcds hex-v2?
  14. RJ-8V
    749
    187
    43
    No, you have to flash it with VCP.
    Verstuurd vanaf mijn SM-G925F met Tapatalk
  15. france71
    france71 Registered User
    127
    78
    I downloaded the OBDEleven app and it suggests that video in motion isn't possible on newer software is this true?
    I would like the following options,
    Video in motion
    Longer hands free
    Longer traffic jam assist before it asks to reset again
    My car is a December 2017 model A4
  16. RJ-8V
    749
    187
    43
    All three options not possible
  17. psychopomp1
    psychopomp1 Registered User
    766
    234
    43
    Hi,
    Does anyone know if its possible in VCDS to always have the rear LEDs on along with the front DRLs as standard?
  18. RJ-8V
    749
    187
    43
    Yes is possible
    Original VCDS Hex-net | VCP | Odis-S | Odis-E | A3 8V Facelift Limousine
    psychopomp1 likes this.
  19. psychopomp1
    766
    234
    43
    Thanks. Will the VCDS coding below work for the B9 (got it from B8 forum):
    Tailights active as DRL's
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 2: Bit 7 - (1 = active)
    LEDs remain at full brightness with parking lights
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 3: Bit 2 - (1 = active)
  20. cuke2u
    13,060
    5,281
    B8 uses different coding I believe, again pm DJAlix as he's the expert...
  21. RJ-8V
    749
    187
    43
    No
    For the B9 you need to set Byte 2 - bit 3 for DRL rear.
    Byte 2 - bit 1 = DRl menu
    psychopomp1 and cuke2u like this.
  22. psychopomp1
    766
    234
    43
    Does anyone know why VCDS isn't able to read some modules on my B9 (eg Module, 46, module 35)? No issue reading module 08 for example. I'm using the latest fully registered version 18.2.1 on a Windows 10 64 bit laptop.
  23. RJ-8V
    749
    187
    43
    Only Hex-net versions of VCDS cables can fully access the latest models (like the B9. F5 etc)
  24. DJAlix
    DJAlix VAG Car Coding™ Limited Site Sponsor Gold Supporter VCDS Map User VAG Can Professional ODIS (Offboard Diagnostic System)
    6,697
    5,120
    ...you mean "Hex" I think as both the Hex Net (Wifi) and Hex V2 (cabled) interfaces will work with no issues. Only reason to purchase a Hex Net interface at the moment is for Wifi capability / VCDS Mobile, or because you need to fully talk with Lamborghini's.
  25. RJ-8V
    749
    187
    43
    Eh no...
    The previous version was Hex-CAN. The new versions are called Hex-NET. Both the wifi or cabled are hex-net
    www.ross-tech.com/vag-com/faq_6.php
  26. DJAlix
    6,697
    5,120
    Nope...
    Hex net and hex v2 are the new interfaces, both work with all cars bar lambo’s, which need a hex net for full compatibility. I use both daily and both work fine on B9’s and alike.
    NevMan likes this.
  27. RJ-8V
    749
    187
    43
    Really...thats exactly the same what im saying. The new interface protocol / connection is called Hex-NET, where the previous was Hex-CAN. With the new versions you also have experimental coding. Its not just the name but the whole interface / software behind it.
    Read your own post! Again a weird response....
    I'm using tools like vcds for longer then 10 years now...also on a daily basis.
  28. DJAlix
    6,697
    5,120
    Now you just correcting yourself as you posted originally that hex net was the only B9 / MLBevo compatible interface. The hex V2 is also, which is not a “NET”.
    The main reason for my jumping in on this conversation is that some people might have taken your advise as gospel and purchased the more expensive interface when in fact they could have purchased the lower cost option instead.
    NevMan likes this.
  29. RJ-8V
    749
    187
    43
    I said versions....plural. I think that we both mean the same, but we have different meanings for "hex-net" . For me both cables are the same. You see the name as the difference.
    Lets leave it like this.
  30. DJAlix
    6,697
    5,120
    Ross-tech sells the following:
    -Hex-net
    -Hex v2
    These are their names, and although mostly the same the “net” has more capabilities. Please stop giving incorrect advice.
    tickedon, NevMan and WesT-gefül like this.
  31. RJ-8V
    749
    187
    43
    The only difference is that "net" has more connection capabilities. The software part is the same.
    Again you stick with the "names" and i use the software part. So not incorrect advise and please stop like you know everything..........
  32. DJAlix
    6,697
    5,120
    Am sorry but you said only hex net supports the B9, face it you are wrong! The back end maybe the same but the interface is not. People taking your your advice might have purchased a £600 hex net Interface as a result when in fact all they need is a v2 £400 one (pricing not exact).
    You may have 10year plus experience but you really need to think before you offer advise on a public forum.
    tickedon likes this.
  33. Avatar
    snack-media
    Advertisement
  34. RJ-8V
    749
    187
    43
    Ok DJALIX, you are right. Ok?
    Maybe the difference is that we use on the mainland the same names for the software/interfaces and in the UK not.
    Really....you are saying that to me? Like you wanted to correct me yesterday with VCP + MLBEVO + Disable startstop? Then you should also think and know the basis before correcting someone.
  35. DJAlix
    6,697
    5,120
    Actually no, Ross Tech invented the naming conventions as it’s thier product and they are based in the USA I believe... so regions have nothing to do with it. The tools maybe “the same but different” but the difference is actually pretty substantial, especially on the price.
    This is a public forum, very very very respected as the community here do not mess about and look for facts. Someone viewing your advice, although not totally incorrect, could have wasted money for no good reason. Simple, that’s it... no more no less.
    As for the Start / Stop comment, no games and not trying to show you up. I simply posted what was in the official documentation for the application in question. You actually showed me something that I had missed, mainly because the VCP update / release notes are never detailed and they are too busy fighting VW Group in an IP court battle at the moment to actually inform their customers of new features etc. Have tested, it works, happy days and thanks.
  36. RJ-8V
    749
    187
    43
    Ok lets not waste any time on this. We both have our disagreements, lets leave it like that.
  37. Sandra
    Sandra Administrator Staff Member Administrator Platinum Supporter Audi Main Dealer
    32,833
    15,070
    Ok, let’s get this sorted. This is a public forum and as @DJAlix has pointed out we are well known for the accuracy of the information that we have freely available to our members. This information must be correct as other members may purchase software that is above their requirements at an extra expense to them and that is not ideal. To have Odis software in your signature you have to be dealer certified and also be a site sponsor. The information you may give a member may not be 100% accurate and can cause damage to a members car and none of this is what we want to occur, If you wish to be on the forums vcds map fill in the details on the link below. On receipt of the application you will be added to the vcds map and will have the forums official vcds banner applied below your avatar. If you wish to be carrying Odis in your signature you must be a site sponsor. Please update your signature by removing Odis and vcp details. Feel free to contact me by PM if you disagree with any of the above.
    https://www.audi-sport.net/xf/applicationform/vcds-application.3/form
    https://www.audi-sport.net/xf/applicationform/site-sponsor.4/form
  38. psychopomp1
    766
    234
    43
    @DJAlix
    I believe you are located in London, do you have any plans to visit N England/Scotland on a VCDS coding tour? I say this as I've almost given up doing the coding myself on VCDS on an el-cheapo ebay kit and I suspect most/all of the issues are down to the cheap cable. What did I expect for £70? lol On the other hand spending £400+ just on a cable is way overkill for me as I only need a few mods done and probably won't touch it again ever wrt VCDS.
  39. psychopomp1
    766
    234
    43
    Re: enabling audio chirping when locking/unlocking car, can this be done through central electric module 09 (which I can access) instead of module 46, which i cannot access? If it can be done via module 09, what are the settings needed?
  40. DJAlix
    6,697
    5,120
    Where are you in relation to Bonnybridge? (Spelling)
  41. RJ-8V
    749
    187
    43
    In 46
  42. psychopomp1
    766
    234
    43
    I'm based in Inverness, however happy to travel to anywhere in Scotland (including Bonnybridge) and parts of N England it it means getting my car coded by someone who knows what they're doing, instead of just your average VAG technician. Will you be visiting Bonnybridge personally or can you recommend someone there?
  43. DJAlix
    6,697
    5,120
    I provide support services to a rather big performance company there. I can see if I can arrange for them to host a remote session between myself and your car if you like....
    NevMan, psychopomp1 and Sandra like this.
Tags:
