Hi, I have just ordered the OBDEleven, are these all one touch coding that are available so far? Or do they require long coding?
Hi mate when I get the bap personalisation and enter the code it comes up with nothing. Any idea what I'm doing wrong?
Can you post a screenshot? Once you've entered the access code it should allow you to change the 'BAP Personalisation' setting. Not sure why it is coming up blank. Sent from my Nexus 6P using Tapatalk
Hi all, does anyone know If there is a code available to enable the visual aid for the parking sensors? I only have the Beeping currently. is there anywhere where all the codes that are available are all in one place?
Well I enabled Lap Timer on the A4 with VCDS which worked but still no Gear Indicator in the HUD even when laptimer is running. Anybody else managed it ?
Obdeleven turned up today. Great bit of kit for the money. Managed to get a few bits done, going to give lane assist a go tomorrow. Hill hold assist is available on my wife's 2017 A3 as an app so must be a way of doing it on our cars. Sent from my iPhone using Tapatalk
I've coded this on mine tonight if your ever near Peterborough let me know Sent from my iPhone using Tapatalk
Thanks Snow Addict. All done by DJAlix and I've subsequently bought vcp. Sent from my iPad using Tapatalk
No problem glad you got it sorted! I'm really struggling to get lane assist to work without getting the pre sense fault at the minute. :-( Sent from my iPhone using Tapatalk
Hi Snow Addict, noticed you mentioned your in the Peterborough area, I'm from here aswell Hampton area and I'm looking to get the Sweeping dials on my A5 B9, is there anyway of checking the app to see if they support the new model yet? I don't have the app or the device so I was hoping if it is there you don't mind doing it
No problem, I'll check it out when I'm back home on Monday and let you know. Don't mind doing it for you if it's available Sent from my iPhone using Tapatalk
That's great thanks, the standard motion looks ok but after seeing them mentioned in this thread and on videos it's quite a nice feature to have. Was this on a A5 Coupe B9? I wasn't too sure as the models only really been released if it was available, guess as the A5 is virtually an A4 It was be very similar coding
ah right, not looked into VCDS too much, the app seems easier to use, defiantly after the needle sweep, maybe lane assist
I presume the speed limit recognition works off the same camera as pre sense so can this be coded in too? Or is there extra hardware required for that?
I have just got the app yesterday. It should be easier as it has the labels - I have just had to report an issue to support as one of he modules I want to access is giving an error and has no labels! Sent from my iPhone using Tapatalk
Can you share your long coding for Central Electrics please? OBD11 just arrived and I have no labels on this module! Support say it will be a month until it is fixed as they are waiting for a new DB from Audi.
Do you have VC? I don't know sure if this coding with needle sweep works with Virtual Cockpit :-?? Thanks!
Sounds good, but I can't imagine how it would be showing in the VC! Maybe can someone make a video or something?
Ah, I see, I also thought the drl's on the A4 were one of the best things. Do you have separate indicators as well?
I was going to suggest activating the DRL sub menu within the exterior lighting main menu, to allow the DRLs to be toggled on and off but VCDS cannot do this. ODBeleven will not be able to do this unless there is an app for it. Only other way to turn off the DRLs would be via the related adaptation channels within 09 - Cent Elect. There might be a global DRL channel but most likely you will need to change each bulb to be off. Am not sure what channels need to be changed off hand. If you can generate an adaptation map of 09 and post it up / pm it I can work out whats needed. My "queue" is a bit stacked up at the moment so there will be a delay in my getting back to you.
Hi DJAlix, don't suppose you know how I'd go about enabling the visual aid for the rear parking sensors? Currently I've only got a beeping. Cheers Sent from my iPhone using Tapatalk
This is something I actually need to test, along with the same feature for the FL A3. The coding side of things I need to test myself before releasing as I don't want to supply bum information that might cause issues, but also mostly because VCP or ODIS is needed. The only other known way to do this is to change / upgrade the park assist module. Don't suppose you are near London at all are you?
I have done this but the network search is greyed out.....any ideas if something else needs to be done as well?
Here you go: 07501143C13900CD014451185B3F00B9130B3108000000000000000060001C810A4502A322B60A Sent from my Nexus 6P using Tapatalk
Thanks - unfortunately I can't work out what was changed as the values are too different from mine!!!
