sandwich1987
im not over concerned about the log itself, as you can see i pulled 3cf's on cylinder 3 at the very end of the power run, and after that i satred to get 0.8 on 3 and 4 a few times and 4.5 on cylinder 3 when driving back home doing 30ish is this a concern??? seeing this timing pull when not actually pushing the car?
On a side note ive been having abs traction problems and looked at block 125 to see the values but cant find anything to reference to they both read 1, ross tech just tells you to look at 125 not what the values should be?
apoliges if u cant really see the log that well im really quite pish at anything to do with excel...
