had the typical transistor failure in the vp44 pump on my b6 a4 2.5tdi, had it repaired but it sounds like the static timing has been thrown off when the pump died doing 70, because its the v6, vcds lite cannot be used to check that static timing using the timing graph function so I'm hoping there's someone local with a full vcds that can help
Regards and Thanks,
Mark
Regards and Thanks,
Mark
