VCDS Fault Codes
Andy Shipton
Hi,
can any body throw some light on these fault codes,i have just started to fit a rear view camera to my A3, i have attached the multi media interface to the connections on the RNS-E and have coded channel 37 navigation to enable viewing when reverse gear is connected ie channel 4 to set from 0 to 1 this seems to be fine but when scanned these faults have come up . Do i also need to tell the navigation that there is a TV tuner as this seems to be looking for this address. should i use the long coding helper on the CAN gateway as this seems to have changed as well.Just to let you know i have RNS-E telephone prep ,CD changer and multi function steering wheel.
Andy
Tuesday,23,August,2011,12:51:01:63343
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 57 62 72 76
77
VIN: WAUZZZ8P05A076898 Mileage: 77070km/47889miles
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Not registered 0011
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104A0506FA
Coding: 3D3F07CA072103
Shop #: WSC 06314 000 00000
VCID: 28546E98E263
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 22
Mileage: 77079 km
Time Indication: 0
Date: 2011.08.23
Time: 12:47:21
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
Component: RNS-E HIGH EU H74 0660
Revision: 04S Serial number: AUZBZ7G0913898
Coding: 0215717
Shop #: WSC 21244 142 61076
VCID: 3874BED832C3
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 22
Mileage: 77079 km
Time Indication: 0
Date: 2011.08.23
Time: 12:46:00
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0215717
VCID: 3874BED832C3
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 22
Mileage: 77079 km
Time Indication: 0
Date: 2011.08.23
Time: 12:46:00
Address 57: TV Tuner
Cannot be reached
Maybe pm nigel (NHN) he may be able to help you out with advise.
