VCDS errors
shariain
Glasgow
Website
www.barshargsd.com
had my car scanned today and this is the error codes that came up. can anyone make anything from these.
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 24001038130777
Coding: BF0F0340070101
Shop #: WSC 06435 000 00000
VCID: 2648736EE88F
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 15
Reset counter: 56
Mileage: 120626 km
Time Indication: 0
Date: 2011.12.29
Time: 18:55:14
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554
Component: HALDEX 4Motion 0101
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: EAD0C75EBC17
4 Faults Found:
16347 - Control Module - EEPROM Error
014 - Defective
02248 - Valve for Controlling Clutch Operating Angle (N373)
014 - Defective
014 - Defective
014 - Defective
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505085AC61000
VCID: F9F2E812C9B1
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
4 Faults Found:
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
000 - -
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 3A70B71E0C37
1 Fault Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
cheers for having a look
Clear all errors & test again.
if the errors come back once cleared, then there may be a real problem - the haldex valve error is a common problem - the pressure sensor fails and the car drives in 2wd mode instead of 4wd - a new pressure sensor is about £45
Cheers for the replies I am trying to arrange to get the car scanned again. The car still drives with all 4's no problem. If I can't get it scanned again soon it's going in to Glasgow Audi on the 4th for the coil recall so no doubt they will scan and clear the faults then give me the bad news about my new car.
Did you have a look over in the vcds section, there is a users map on there who may be able to scan for you.
It's a friend of a friend who has the software at his garage but it's going in for a recall so doesn't make 2 much difference if I can get it scanned again.
did you fix the fault with your haldex,i have the exact same problem with mine and am not sure how to fix
