VAG DPF Android app
jakm15 Apr 12, 2018
  1. jakm15
    jakm15 Member
    56
    23
    I’m getting an android phone later today and hoping to use the VAG DPF app to check the health of my DPF and moniter a regeneration if it needs one, the fans been running after driving short distances recently so I suspect it does.
    Quite a bit of info on how it works here
    https://www.briskoda.net/forums/topic/423341-vag-dpf-app/
    Has anyone had a play with this app?
    Adi Meister likes this.
  2. Avatar
    Google AdSense Advertisement
  3. tech838
    tech838 Member
    41
    14
    Yeah its actually quite good if you have an engine that the app supports.
    I thought I'd give it a try for the 3.0 TDI but its not supported, and having emailed them there are no plans to add it.
  4. jakm15
    jakm15 Member
    56
    23
    Just had a try the other day with my CAGA engine, came up around 500 miles since the last successful regen, 15g of soot and 0.1 of ash and the dpf was 66% full.
    Went on the motorway at a pretty decent speed for about 10 mins and the exhaust temp was around 350 then the ecu must have gone into regeneration mode and it shot up to around 780c and the soot then dropped quite quickly to 4.5g and 25% full.
    The cars on 82K on a 10 plate so the dpf looks pretty healthy looking at that.
  5. Retroman
    Retroman Audi A3 2010 Sportback 2.0 TDI 170 (CBBB engine)
    1,046
    331
    Thanks for pointing this out - have just installed it :highly amused:
  6. feva
    feva Well-Known Member
    845
    454
    Excellent find appreciated
    Sent from my Note 8 using Tapatalk
  7. jakm15
    jakm15 Member
    56
    23
    No problem, I’ve been using my carista Bluetooth OBD connector so if anyone has one I can confirm it works with this app.
  8. Marky007
    Marky007 A4 Sline Team Silver TDi saloon Audi A4 S-line owners group Manual
    283
    90
    Just used in my 2012 a4 soot is 6.25 great free app.
  9. Leyton388
    Leyton388 Active Member
    125
    72
    What a great find this is.
  10. Marky007
    283
    90
    Thats what mine says on free app. Have bought full app but yet to try it. It has alot more features.
  11. Marky007
    283
    90
    Full paid app shows dpf ok at 79k
  12. Avatar
  13. feva
    845
    454
    Going to take mine for a 1hr run tomorrow, showing 16g of soot and 532km since last clean. Hopefully that will burn it clear.
  14. feva
    845
    454
    Well 1hr blast and it's now like this? Does that mean it's 80% full? [​IMG][​IMG]
  15. jakm15
    jakm15 Member
    56
    23
    It’s not regenerated on that drive you went on, you know when it’s doing it becuase the exhaust temp goes up to about 600c and the soot starts dropping quick, then the time and distance will reset when it’s done.
    It is due a regen looking at that but it just depends when the ecu decides it needs one.
    I’ve read that you need a decent amount of diesel in the tank or it won’t regen, not sure how much truth is in this.
    It looks like you need to turn auto refresh on as well, go in settings and look for something like auto refresh or similar and turn that on then the values will refresh as your driving, i wedged my phone in front of the steering wheel.
    Mine started a regen when it was around 16g and I accelerated hard to a pretty decent pace 100mph plus (on a private road) for about 15 mile.
    feva likes this.
  16. feva
    845
    454
    Cheers jakm15 appreciate the feedback. I'll change it to auto refresh. Had a fuel tank of fuel. Shall we say it was a spirited drive
    Just going to keep an eye on it.
  17. Marky007
    283
    90
    I went along to pick my daughter up was around 72% when i got back heard fans going so checked was down to 29% was 2 miles there 2miles back but i was sitting in car park waiting with engine running waiting for my daugther for 10mins before returning home.
    It still says on app it has not done a regen in 190miles :wtf:
  18. Chris90
    Chris90 Active Member VCDS Map User
    689
    236
    43
    They dont regen on a spirited drive I dont think. Just a steady drive at 50-60mph in 4-5th gear should do it.
    feva likes this.
  19. Marky007
    283
    90
    Am just going to let it get on with it seems to work well. . .
  20. jakm15
    jakm15 Member
    56
    23
    I think the regen miles resets after it’s done a full successful regeneration not a partial. Mine did the same the other day when the Mrs came home from work, it’s only about a 3 mile 30mph drive and it nearly did a full regen then.
    I think your right, it seems to look after itself even when you do short drives.
    Marky007 likes this.
  21. feva
    845
    454
    I've got a drive to Bradford (1hr 20mins) tomorrow so I'll get to a steady speed and check once there. Cheers Chris.
  22. Seanchadwick2k3
    Seanchadwick2k3 Audi A6 C6 2.0tdi 2011 Sline Special Edition Audi A6 S-line owners group Le Mans Edition
    382
    197
    43
    Ive been monitoring this app quite a bit, from my findings the amount of.fuel you have doesnt make a difference, also really high speeds dont help. Ive tried belting it to get it to trigger at only 50% full with no joy. I think it does it when its ready, for me its been anytime after say 70%.
    Last time I checked it was at 82%, I tried putting my foot down to get the temp up but it didnt trigger. I then stuck to 55 cruise control on and it suddenly decided it was time, temp.shot right up and the process started, another mile or two and all done
  23. Marky007
    283
    90
    You can get live feed from it every few secs just press the two round cirles looks like a voicemail button :thumbs up: see what its doing on drive there . . . :racer:
    I place my phone over mmi screen set app to landscape :whistle2:
    feva likes this.
  24. Marky007
    283
    90
    Maybe to high speed wont let it get upto temp . . .
  25. wilco184
    wilco184 New Member
    19
    Hi,
    I don't have this app, but I've noticed with VCDS that the threshold for an active regeneration is noted as 'charge limit for field regeneration'. For me, this value is currently 22.77 Grams. The limit depends on the oil ash residue, as mine recently lowered slightly when the oil value changed to 0.11 Litres.
    Regards,
    Matt.
  26. Seanchadwick2k3
    382
    197
    43
    From what ive read you can try as hard as you like to raise the temps to regen levels but you won't get far. The ecu decides when its time and injects more fuel to raise egt's enough to burn it off which is why you can sit at say 50mph whilst it does its thing.
    Under normal conditions no way would you hit 500 degrees + doing 50mph
    feva likes this.
  27. Leyton388
    125
    72
    I did a scan and it was on 62%. Took it on a run down the motorway and on the second reading it was 10%.
  28. feva
    845
    454
    After it reached 100% it started a clean cycle. [​IMG]
  29. Marky007
    283
    90
    I thought they started about 80% nice to see some low soot mass
    feva likes this.
  30. feva
    845
    454
    Marky007 I was watching it climb and climb thinking "oh dear "
  31. Marky007
    283
    90
    Screenshot_20180511-193248.png thats we're am at :yahoo:
    feva likes this.
  32. jakm15
    jakm15 Member
    56
    23
    I wonder why it stops at 6grams, mine did the same
  33. Avatar
  34. feva
    845
    454
    The father in laws Vw tiguan does the same
  35. Seanchadwick2k3
    382
    197
    43
    Same here, never goes to 0
    feva likes this.
  36. Marky007
    283
    90
    IMG_20180513_140123.jpg Had mine do full regen today went to 100% then kicked in . .
    feva likes this.
  37. feva
    845
    454
    Good to know it's not just mine that when to 100% Marky007
  38. Seanchadwick2k3
    382
    197
    43
    When I got the app I checked my dads passat for him and it was at 110%! Quick trip down the motorway and it was all clear
  39. jakm15
    jakm15 Member
    56
    23
    Mine was at around 70%, as soon as I clicked the cruise control on it started regeneration. Not sure if this was a coincidence or not.
