Vag-com
M4KTT
How much will it cost me to get set up on my lap top to monitor things through vag-com?
eg lead, software etc...
Can it monitor lots of things whilst the car is being driven?
Woorlord
shifting to Hyperspace... .
Software is free to download direct from the Ross-tech site.
The lead is the trick - a genuine ROSS-TECH USB HEX+CAN is where you need to spend the money Link (Ross-Tech $349)
I paid around £200 direct from Ross-Tech inc. shipping when the £=$2, guess won't be that price for a few years yet! I recall UK web sites were around £260'ish + P&P.
Are there discounts through this Forum site perhaps??
Yes - you can use the VAG-COM (actually called VCDS now) software to real-time monitor various aspects of the ECU and other control modules throughout the car either numerically or graphically through control block channels, etc.
BILKO1
Might be worth sending a pm to NHN on here as he has a good deal on genuine cables atm.
jb0o
Whats the down side to buying a £11 VAG-COM cable from eBay?
BILKO1
No back up or support, also won't work on later cars like the one in you're sig.
Woorlord
You can only read DTC errors and perform a reset.
I believe it gives you the DTC error numbers and does not give the actual "text" meaning.
You are limited to using "old" software versions of VAG-COM and can not utilise the latest version 805, hence newer cars may not be supported.
No ability to access the "Advanced" features of VAG-COM, i.e. programming & configuring modules (required if repalcing a module), monitoring measuring blocks, etc.
Non-Genuine cables are very unreliable with regard to communication - may not always work! This is because they rely on software drivers on your PC to emulate a genuine cable. However, Gen Cables have a software/hardware installed in the actual cable to correctly communicate with the car.
Non-genuine cables have a tendancy to "blow up" the cable driver circuit and then become "dead" if you have a after-market stereo which may put +12v on the diagnostic pins. Genuine cables are elctrically protected to overcome this.
philipposx
Hey guys , how about this site here? Looks good but I am not sure whether it fits the European made A4 cabrios...
I am thinking about it since it seems to be ...cheap money.
