vag codes for an a2
1wheelonly
cabriolet
The Lounge
hi
has anyone got any adaption codes for a a2, a friend has bought an a2 and want to activate beeps on alarm etc.
got full vagcom but could do with some advise. cheers
46 and coding. Not done one before but might pop up in a helper box. If not have a look at the label file.
cheers stu
had a look earlier before the post and no pop up helper box,what do you mean by label file.
sorry if i sound dumb,still newbie with vagcom.
thanks again for that test by the way, got it sorted now, it was a leak.
cheers mate
If you look in the root ross tech folder you'll find a folder called labels. using the part number of the controller you are looking at you can normally find the txt file which is the lable file Vag-Com will use to help with the coding.
