vaccum pipes
woodycufc
carlisle
hi can anyone help me,
vaccum pipes have broke, the ones that are attached to 06A 131 541 vaccum reservoir.
id like to renew all the pipes but what do i need please help coz im thick and not a mechanic but i do try!
thanks
You can also look at replacing them with suitably sized silicon vacuum hose but you would need to measure the relevant ID's of the existing OE hoses to gauge the sizes you need...
Vac leaks ...... Should Idle smoothly with the air-con ON, hunts probably air leak , Brakes , left over night should have several
brake applications left before the peddle stiffens up , watch for splits in the the hard plastic branches and one way valves
leaking ..
726
593
H
23
HansfishS3
H
