V6T decals removed
Flowrider99 May 31, 2018
  1. Flowrider99
    Flowrider99 Active Member Team Mythos Supercharged TFSI Owners Group Team V6 Sportback Audi S5 Black Edition quattro S tronic
    303
    134
    43
    I have removed the V6T decals from the wings on my S5 but on one side the car has had some paintwork repair and you can see that the decals were not removed before the wing was painted. It looks like it may be just clearcoat overspray, what can I do to smooth out the clearcoat and remove the V6T outline?
    xpoweruk likes this.
  2. Avatar
    Google AdSense Advertisement
  3. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 S tronic
    16,594
    2,394
    I had ghosting on mine,I just used quick detailer.
  4. Flowrider99
    303
    134
    43
    This is not looking good....I have taken to car to a couple of body shops, both think the wing needs a complete respray with one quote at £300! Still waiting for the other quote.
  5. voorhees
    16,594
    2,394
  6. Flowrider99
    303
    134
    43
    You would think something can be done without a respray. Its only clearcoat sprayed on top of clearcoat to blend the new paint in.
  7. Flowrider99
    303
    134
    43
    Might end up doing just that.
  8. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator Audi A4 Audi Avant Owner Group
    9,932
    13,985
    @Flowrider99 - ^ This :thumbs up:
    T-800 likes this.
  9. JG51 AUD
    JG51 AUD Well-Known Member Team Glacier Supercharged TFSI Owners Group Team V6 Gold Supporter Audi S5 Black Edition quattro
    3,157
    1,973
    Probably get shot down in flames for suggesting this, but, wet sand & polish??
    JG
    MattSedg likes this.
  10. Flowrider99
    303
    134
    43
    Thats what i was hoping the body shops would suggest. I might give it a go as i have nothing to lose. The clearcoat has chipped a little around the badge outline since i removed it so putting the badge back may no longer be the solution.
  11. JG51 AUD
    3,157
    1,973
    Touch up chips with clear coat and then wet sand & polish, as you say, nothing to loose.
    Body shop will want to do full wing, more £'s in that job.
    JG
  12. Avatar
  13. Flowrider99
    303
    134
    43
    Sorry, i should have said flaked not chipped around the edge of the outline.
  14. JG51 AUD
    3,157
    1,973
    It's still worth a try.
    JG
  15. Flowrider99
    303
    134
    43
    Got another quote, this is to respray the wing properly, £220. Its way more than i hoped but now that i know the wing was not done peoperly in the first place i think i may bite the bullet and get it resprayed. There are some other blemishes on the wing too so they will also be sorted out.
    JG51 AUD likes this.
  16. JG51 AUD
    3,157
    1,973
    At least you'll know it's been done right this time, if not, you'll have a come back with the body shop.
    JG
    Flowrider99 likes this.
  17. Flowrider99
    303
    134
    43
    Decided to try and fix this issue myself, i have sanded the area and removed the badge outline and now have to either wet sand the area with very fine sandpaper or maybe some rubbing compound, not sure which. I have been using T-cut to remove the scratches and bring the shine back but its not working.
  18. JG51 AUD
    3,157
    1,973
    Just a suggestion, Meguiars 105 Ultra Cut Compound, then Meguiars 205 Finishing Polish, you may need to do the job with a DA Polisher though???
    JG
    Flowrider99 and jassyo06 like this.
  19. Flowrider99
    303
    134
    43
    Success.....the badge outline has gone. Its not a 100% fix but it is good enough for me. Here is what I did........
    1. Sanded the area with a medium grade sandpaper.
    2. Wet sanded the area with 2500 grade sandpaper.
    3. Halfords Super Fine Finishing Pad.
    4. T-cut smooth out any light sandpaper marks.
    5. Polished area with Autoglym Super Resin Polish
    6. Applied Autoglym Extra Gloss Protection.
    I think a DA polisher would complete the task perfectly but i don't have one.
    scotty76, jassyo06 and JG51 AUD like this.
  20. JG51 AUD
    3,157
    1,973
    Great job, a lot cheaper than getting it sprayed, and more satisfying doing it yourself. :thumbs up:
    JG
    jassyo06 and Flowrider99 like this.
