No problem buddy glad we could help.Naa quite easy 2 nuts n wire cheers for the help guys
Is that the fuse with the airbag connection?Well that didn’t last long, either it’s a **** fuse coz I couldn’t compare it or what could be over powering it causing it to blow so easily, any suggestions am very close to just burning the thing because I don’t have the best patience
If you don’t connect the airbag connector I can’t see how it can blow. As it’s only job is to blow when it’s receives a signal from the airbag connector, so my guess it that if it’s not a genuine fuse it wasn’t rated high enough.So if I was to go buy a Genuine Audi (any ideas on price bye) it could be ok? But all in all am ok with engines but electrics are my kryptonite.. always get electrocuted
I just bought one for my RS3 and it was £37, surely it’s got to be the same part?I think there more £90 ish from Audi that was a few years ago too .
Its definitely should not rattle or make any noises
That would probably make sense then if they fitted it.Could be unless mine was £90 fitted will check invoice . . . .
If it started fire with bodge I would say starter is fine.Am now thinking after numerous searches on line and forums that the intermittent starting, throw in the bad battery and the fuse that was more bodged than Pete burns that it’s probably going to be the starter motor, anyone know of a guide pref with images of how to remove it on the A4
