Upgrading to navigation plus rns e
Ian Kelly Jul 5, 2017
  1. Ian Kelly
    Ian Kelly New Member
    Hi new to this
    Looking at upgrading the radio to navigation plus rns in a 2010 A3 s-line
    Does the unit need a key code and will I require the Gps antenna and where can I buy one from
    Regards Ian .
  2. Avatar
    Google AdSense Advertisement
  3. MarkWizard
    MarkWizard Active Member VCDS Map User
    350
    Yes, yes and eBay
  4. MarkWizard
    350
    Maybe wiring changes depending if you have Bose and coding via VCDS. Search on here for threads there's 100's
  5. Ian Kelly
    thanks
    Is the VCDS when you connect to the cars computer and you can switch functions on and of and reprogramme, luckly i know a man that can
  6. ch1z64
    ch1z64 C'mon you's bhoy's in Green Team Imola TFSI Owners Group Silver Supporter Team Sprint Audi S3 Manual
    3,564
    759
    yes it is mate
  7. Ian Kelly
    ok
    system is in and coded all is working well, apart from Aux socket in centre console
    i know that i need to remove the pins and place them in the 32 pin socket (on order)
    my question is i have a 30 pin iPod socket in the glove box this is working fine but will this be affected by getting the aux working
  8. ch1z64
    3,564
    759
    for your Aux to work you need to move 3 wires from the bblue block in your quad lock in the back off sat nav.
    B1>22
    B3>21
    B7>06
    ( 22 21 06 onto your 32 pin av connector ) as for this interferring with iphone that i am not sure
  9. s8craig
    1,840
    65
    Should not be an issue as the Ipod will be coming in on the CD changer port and the AUX is seperate.
