Updating to 2016-2017 maps query
scoss
Been meaning to do this for ages. I have copied the files over to the SD card. Works out just under 2G.
Question is do I have to delete anything before I update? Or do I simply update from the card?
Rob2k68
Well-Known Member
Just update from card.
Rob2k68
Well-Known Member
The 2017 update should be due any day now.
Rob2k68
Well-Known Member
Where do you get notification of this?
You don't mate - just have to keep checking the my.audi sit - when it's available the map update thread will generally alert people.
73pop
I just can't get it to work!!
Downloaded the maps but them on a formatted sd card go to system update then it doesn't recognise the sd card just stays grey? Will it make any difference that I am using a mac?
G
Gordo77
Guest
Downloaded the maps but them on a formatted ad card go to system update then it doesn't recognise the ad card just stays grey? Will it make any difference that I am using a mac?
Did you format the SD card?
G
Gordo77
Guest
Ye I did but there was 4 different options on the mac. I also couldn't download load it straight to the sd card had to put it on desktop then drag it in to the sd card
MS-DOS (FAT) would be the one to go with:
Should be fine dragging onto the SD card after its downloaded.
scoss
Just to clarify the new update will be 2016-17? Will it's file name be called this? I downloaded mine file back in June of this year.
Rob2k68
Well-Known Member
From last years November update I'd expect it just to say 2017.
G
Gordo77
Guest
I'm currently downloading the full package to see what it gives me. A 12.9Gb zip file called 02300016.zip is downloading as we speak.
Rob2k68
Well-Known Member
Rob2k68
Well-Known Member
Rob2k68
Well-Known Member
G
Gordo77
Guest
Yes indeed says complete just unzipping to destination on your PC or to the SD card. Is that the full Euro download ?
I went with the full Euro download. Will need to check what version I have in the car, but here is what 's been downloaded (about 15Gb worth of files)
will_0407
Just updated mine, downloaded the UK and ireland maps as I have no plans to drive abroad so it was only a 1.2Gb download. Copied to my sd card (wiped it before copying), put it in, mmi settings, updated...done! I have mmi plus so it copied to the internal HD. Seamless for me and a nice surprise that the map updates are free.
scoss
From Audi UK just now regarding the update
@scoss We've not had a confirmed date yet. However, as soon as this is available, we will let you know. Thanks.
scoss
Ive got the tech pack so this is what I'll be doing!
mistac
I assume you all have mmi plus/tech pack rather than standard sd nav?
scoss
Out of interest how long did the update take?
