under boosting
stumpy83
one legged wonder
fitted my boost gauge today and found it to be only boosting at 3 psi?
which iirc it boost 8 psi?
ive tried to find a leak but only found two breathers that was split and perished. once replaced didnt make a
difference...
can anyone point me in the right direction?
i would like to run vag com to try and check the maf is working right, if someone can advise me how to i would be
very gratfeful please
S3featesV9
Slight kink in the pipe you fitted? I had similar issue when I installed my gauge
stumpy83
one legged wonder
checked that i also ran a second pipe to make sure of that
s3dave
TFSI Hybrid
Supporter
Really could do with it on VCDS to rule out boost gauge...
Syvo
IF IN DOUBT GO FLAT OUT
check there is nothing blocking the pipe on the gauge mine had a bit of plastic covering it when took it out of the box also i think it should be 10 or 12 on s3 mine is 10psi on 1.8t quattro standard
stumpy83
one legged wonder
Defo not gauge seen it working in another car an pipe is clear as a whistle??
Gonna hook it up with the solus tomorrow on the digi boost gauge to make sure
100%
What else could it be MAF??
stumpy83
one legged wonder
So I feel a little sill I had a another look over the engine today
And found the MAF sensor was unplugged abit.
Now it's boosting around 5 and 6 psi
slowcoach3
Thats good its running higher but shouldn't it be 11/12 psi? I don't know if the autos are differnet but shouldn't most 1.8t's run higher than that...
stumpy83
one legged wonder
I'm a little unsure?? I was told standard psi is around 8?? I could be wrong though?
Prawn
My other car is a MINI!!!!
Grrrrrrrrrrrr. If you *****es don't know, don't post :angrymod: you'll only confuse the poor man.:whip:
Shauns car has an AGU engine, so has no boost sensor so it can't be checked on VAGcom or a solus. the ONLY way to measure boost on the AGU is via a mechanical guage.
Also, 6psi is about bang on for a standard 150bhp AGU. 10psi is for an AJQ/AUQ 180bhp engine.
Sounds like it's running fine to me Shaun, MAF logs looked good when I came out with you, peaking around 120g/s which is bang on for a standard car.
