  2. Dismiss Notice
Tyre size for 19" rims
PhilipSta Nov 8, 2014
  1. PhilipSta
    PhilipSta New Member
    Hi guys,
    I am looking to get some 19" rims for my S3. I currently run the stock rims and tyres (225/40 R18). Should I be looking at 235/35 R19 tyres as they only seem to be 1.6% larger in diamerer and won't offset the speedo too much? I'm also considering getting ABT's 400hp chip so wider tyres would benefit the extra torque? What tyre sizes do you guys run with 19" rims and why?
    Cheers!
    Regards from freezing Finland.
  2. Avatar
    snack-media
    Advertisement
  3. monopole
    monopole Guest
    235/35 because they give you 91Y and sit better on 8.5 19"
    Unless you're going wider wheel!
  4. Marc18
    Marc18 Well-Known Member Sportback Team Vegas Yellow Audi S3
    461
    311
    All depends on the width of the wheel not the diameter. I run 235/35r19 on my front and rear. Fronts are 8.5j and barely stretch, rears are 9.5j and have a small amount of stretch. Tyre size will be important if you plan to lower the car quite a bit in the future too
  5. PhilipSta
    Thanks for your replies.
  6. C3peeoh
    C3peeoh Active Member
    51
    108
    33
    There is a bunch of stretch from a 235 on a 9.5 inch wide rim. I ran 235 on a 9.5 while waiting for my Michelin PSS3's to come in from the states on the Scirocco.
    It practically turned the 35 profile into 30 profile from the stretch.
    For no stretch at all on a 9.5 it would need to be a 255 or wider.
    On these cars, if you want to run a fairly wide rim then you will need some stretch to avoid rubbing.
  7. Marc18
    461
    311
    Stretch isnt that much compared to what most run, definitely not enough on an 8.5 to get properly low
  8. 45bvtc
    45bvtc An AUDI SQ5, RS3, TT aholic... Supporter SQ5 owners group Team Cornflower Blue Gold Supporter Team Sahara Silver Team Sepang Audi RS3 Audi TT
    7,390
    14,634
    Don't forget to look at the RS3 that was fitted with 19-inch rims and 225/35s on the rear. Several RS3 owners run 235/35s and they do occasionally 'kiss' the inner wheel arch protectors. The standard RS3 front tyre was a 235/35 (255/30 option) but the RS3 had an extended carbon-fibre front wing to accommodate these.
    Here on 255/30 fronts and 235/35 rears:
  9. PhilipSta
    Would BBS SR 8,5X19 ET46 LK5X112 rims fit neatly with stock S3 suspension without rubbing any arches? I'm thinking about the offset as the standard ones have an ET51 I believe? Does someone know what the minimum ET can be with 8,5X19 rims without having to make any body modifications?
  10. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,842
    4,756
    Is the standard Load Index and Speed Rating 92Y XL
    It is on the 3 door !
  11. C3peeoh
    51
    108
    33
    There's enough stretch there that you have no protection for the rim.
    The rim sticks out far more than it should, or as all the cool kids say it has a lot of 'poke'.
    I'd prefer to run a tyre that fits properly, protects the rim and provides more grip. That can only be done if the rim sits under the guard enough to run the correct tyre profiles.
  12. Avatar
    snack-media
    Advertisement
  13. Marc18
    461
    311
    I still need more stretch if I'm to keep these wheels I think. Stretch has its purpose as well as its drawbacks. Once my air is fitted I'd like the arch to sit nicely on the rim once they camber in but we'l see how I go with these.
    Call it poke or whatever, some people love it, some dont.
    I want my a3 laying frame with either some big rear wheels and nice fitment or some smaller wheels tucked all round. Haven't decide yet, we'l see what happens for show season next year
  14. PhilipSta
    Can someone tell if offset was 32 instead of 46 would it still fit snug without any modifications? Would ET32 be better than ET46? Sorry I'm unable to do the measuring myself at this point in time.
  15. Peto Pedro
    Peto Pedro Guest
    OMG 255/30 on audi a3 based?? mmgg that will properly stick out ..
    and 255/30 fronts and 235/35 rears ???? why front wider tyres and back narrower ??? :wtf:Shouldn't be opposite ?
    And still 255 width is overkill for A3/S3/RS3 series .. That is for A4/A5 onwards ..
  16. 45bvtc
    7,390
    14,634
    Erm... :readit: No...
    Above is OEM STD; the 8.5J front with 255/30 was 'option' - and I have BOTH the STD 8J front and rear for winter and 'option' for summer...
  17. 45bvtc
    7,390
    14,634
    And the difference between an 8.5J with a 255/30 and an 8J with a 235/35 is:
    And fits under the 8P RS3 carbon fibre front wheel arches just fine....
  18. Peto Pedro
    Peto Pedro Guest
    Thnx showing up
    MG those 35 profile is way too skinny it look awful .. am checking it here :
    there is no tyre rubber left :D you must feel all stones and humps and bumps very hardly on uk BAD roads :)
    I have now 225/45/17 .. Brigestone potenza S001 great tyres
    What is the limit for my A3 TDi 2.0 I thinking 18'' 19'' is overkill I would say .. :D
