Hello I am new owner of a4 b9 2018. i have one minor problem... When i turn off engine, radio still playing till i open door... How to chage that? Can you poin me where? I wanna that with engine radio turn off also. tnx
I'm sure there's an off button for the infotainment system. It should be on the same row as the drive select but on the right hand side at the end
You can turn the display off but not 100% sure ya can turn the volume off? Sent from my VOG-L09 using Tapatalk
That's normal behaviour I think, unless you manually switch it off by long press on volume button, I think short press just mutes volume. My wife's 2013 Fiesta does exactly the same, so perhaps it is an automotive commonality.
I think it’s common on push button can key. Usually when you take the key out it cuts power to everything. Push button just turns off the engine while opening the door cuts the power. In most cases anyway. Sent from my iPhone using Tapatalk
No, it can't be from my knowledge and is normal behaviour for all the more recent cars I've owned. Is it too much just to press the volume button?
