Turbo Timer
R1KVX
Hi Guys thinking of buying a timer turbo, just wondered if any of you guys have got one fitted or is it no worth bothering, & just leave it running while I sit in it for a few minutes?:think:
S3 TAM
Pocket now empty
I wanted one as well but no sure how to fit them. I just get out and have a fag while it cools down. also for the last 5 mins of journey I try not to boost at all.
If you manage to find a decent one and know how to fit it i might be interested. having a fag outside in the winter is not good.
I was offered one for free but i didnt want one. Main reasons being that insurance dont like them, due to your car being left running. Also asking for trouble as it would mean messing with the immobilser. Plus s3 has a water pump overun which is designed to cool the turbo, this coupled with steady driving should see you no problems with your turbo.
Badger 5 Edition...Its all about the flow...
Staff member
Moderator
1.8t's already have after run water pumps that do much the same thing...
jimmp
these engines have water-pump run on??!
How does that work? is the water pump electrical?? Is there a second water pump...?
Welly
335D Driver :-)
Good luck fitting one and getting it to work with the OEM alarm system.... I'd avoid.
barters3
there still wont be oil flow to the turbo once the ignition is off.
But as already stated i just sit in the car for a min or two.
Welly
335D Driver :-)
Thats the best way IMO
barters3
Ive never had a car fitted with a turbo timer but they would be pointless for me as i live on a hill and i wouldnt be able to leave the car in gear!
Dazboss
Like A Thristy Dingo ;)
Mine dont have the electric water pump after engine shut off :(
Staff member
Moderator
think you will find it does.... they don't always work of course :)
Dazboss
Hummm i shall have a look as its above the rad driver side isn't it ?
If i have, how do i fix it ?
Staff member
Moderator
Depends on whats wrong with it )
Fuse blown, dodgy wiring and ******** pump are the likely choices....
Not sure but the fuse may be one of the ones on the top of the battery...
Dazboss
Fuses on top of the battery are fine, found the fuse for it No. 16 10a micro which is fine.
Where do i find this pump then Tuff ?
