Efterlyst
Gävle
Hello! I have a c7 rs6 with a blown out turbo / turbo charger. I am well aware of the job that has to be done, I know it is a pretty complex work. How much would someone with the capability and right equipment charge for such a thing.
How have you managed that? Is it tuned?
Haven’t heard of too many blown turbos in RS6’s tbh
Who did the tune if I may ask? Firms like DMS purposefully keep the boost lower than sole to keep it within tolerance limits.
Its about 6-8 hours iirc labour time to remove the turbos. Front bumper has to come off and front end put into service mode as the charge cooler needs to come off. Then its the cost of the turbos whether you get recon ones or brand new oem from the dealer. plus you might as well change the oil screen whilst they are in there. Gaskets, seals o rings oil change etc need to be added on top.
Just depends where you are as well
So about 20 hours total work?
I’m paying a guy then not a firm.
Also I’ve heard you need an engine lift. Can someone do this without it?
Why not? Because you wont. Turbos are on top and none of the work is done from underneath. Yes i know! ... i have done it.
Have you changed on rs6 c7?
Audi themselves had to use an engine lift. They said
No idea why they would think they would need a engine lift when all the work is done from above. Unless they want to take the cats off completely?
Yes ive done this on a C7 RS6
Yes i belive they took the cats of completely . But now I’ve established it has to be changed so it would no longer need an engine lift? How many hours did it take for you change?
When i look for recon ones on eBay they always say “upgrade” in the title. Could you send me a link to a good option for replacement?
Example, could this one work? I have no tune on it now, only sport cats.
Just yesterday I got all the way down to taking the turbos off as I was replacing the turbo screen because of this reason,took about 10 hours steady away,the tools you need are basic really,and there’s a full right up on here I think to do the job,I’m a joiner by trade but have a little knowledge of car mechanics
Reactions: RAF_S7
I’m impressed, even though I’m reasonably competent around my car, I’d be slightly daunted undertaking this job!
What turbos/supplier did you go with, and did you get stung with import duty if sourced from Europe/China, or were you just stripping down to do the oil screen job?
Everything working ok now? A lot of people (and suppliers) recommend taking the oil screens out and not replacing, was there a reason you decided to put the latest version back in?
Cheers, :hi:
John
Did you make a decision on which turbos to purchase! EBay seems to be a bit of a minefield.
looking for a set to upgrade my S7 to stage 3 :racer:
Cheers, :hi:
John
I was just replacing the turbo screen but while I was in there I replaced the pcv valve,check valve and control valve just while I was down to that point,I live in the UK so no import charges,I replaced the screen with the newest Version as it was only £4.61 and my old one lasted 58000 miles and probably not do that many miles in the car again,I don’t know with out it it would affect oil pressure to the turbos,I know loads of people don’t put it back in and all is fine,I put the car back together with no problems and all is fine,I’m a joiner/Carpenter so if I can do it anyone can,it’s a big job and a few bolts I had to loosen just by feel but other than that is quite straight forward
Reactions: RAF_S7
