Tuning on 2.0 TDi 140
Ian_C
Dorsprung Turch Vechnique
Glasvegas
Not very familiar with this lark lads so enlighten me.
After the missus instructed me to go for a diesel A3 we’ve spotted the ideal spec, but its not a DPF 170.
After checking out Star Performance (they’ve fitted Cruise on a few of my A3s in the past) they say they can use software to increase the 140 to 180bhp.
http://www.starperformance.co.uk/audi.htm
I’m not savvy with this – what does it involve and is the end result a pure 180bhp, like they say?
I’d appreciate at any thoughts/advice - !
Basically they change the instructions in the engine ECU. When a manufacturer specifies the settings in an ECU they have to take into account that it will be used in hundreds of engines which all have the same specification but with an allowance for manufacturing tolerances. They may also decide to err on the side of say fuel consumption rather than maximum power as an example.
What people like Star Performance and others do is to modify some of those settings to get increased performance from your particular engine without loosing to much in other areas. Some times a 'chipped' engine can give more performance and better fuel consumption - it depends on the individual engine and the new ECU map as it's called.
Depending on the age of your car your could invalidate any warranty given by Audi although many of the tuning companies do provide some form of warranty on any engine they re-map.
The best thing to do is to see if you can try a car provided by the tuner to see if it makes a real difference compared with you own. Some engines already produce more than their basic specified output when they leave the factory. If it's a 103kW (140bhp) engine it must produce at least 103kW but it may well already produce more. Most tuners can test the output from your particular car on a rolling-road before they start any work.
Dave thanks for taking the time. Good explanation.
Presumebly there would be a noticable difference if the thing can be tuned up to 180 from 140, certainly more punchy.
If anyone has performed this o their 2.0 140 then let me know - i'm a bit apprehensive of dropping from the T FSI @ 200 down to 140...........
You could buy the 170 engine then no need to start remapping and potential warranty worries? Unless you decide you want 200+bhp again...
From reading other peoples thoughts on the 140 engine after its been remapped they all seem to rave about it.
Milltek Turbo Back Exhaust + Custom Code Phase 2 = £900, you'll be well happy, quicker than a std Mk5 GTI as Mikey has proved several times.
You did the right choice to get the PD140 instead of the PD170. There are lots of things that can be done to tune a PD140 some of which are in my sig. Can Star Performance maps be switched off or removed and your stock map reloaded?
Only £900? Surely not...
That reassuring information.
I'm so used to the power of the T FSI, i'd miss it if i dropped downt o the 140bhp. Tuning it up to 180bhp sounsd as if it will still be a rapid machine.
You may find you miss it less than you think. Even the 140 TDI has 320Nm of torque compared with 280Nm on the 2.0TFSI. Torque is more usable than utlimate BHP which is only produced at high revs on a TFSI.
i got 185 bhp with milltek cb, green air filterand next week put downpipe. once uve done remap u gonna love ur car. i was going to sell main cus it was boring but after remap i love it again a lot more... then u wanna put some more stuff in it... so enjoyable. just keep servicing etc...
I just had a reply to my email to Chipped-UK asking a re-mapping the new 140 common-rail engine.
"This is the new edc17 ecu, we can make this software for you, gains are
typically 38hp and 65-80nm torque.
We only offer custom tuning of this ecu due to the nature of the ecu type
and the cost is £380 inc vat. This comes with a full 3 year warranty backed by an exclusive insurance policy.
The difference is a far smoother yet more progressive midrange power
delivery, overtaking at road speed will be far easier requiring far less
effort than in original form"
As I have a 140 on order and currenty drive a 170, despite what I've said in the past about re-mapping, I may even be tempted.
The 170 cost £910 more than the 140. With this remap you could get an increase to 178bhp and 385-400nm of torque for £380.
It sounds good for that money, but looking at the contact list in my area it suggests a mobile tuner, so there's no shop or place that you can visit if something goes wrong.
Unless, of course, you fancy a drive to Bromsgrove.
