TTE700 EVO Upgrade Performance Turbocharger 2.5 TFSI
Introducing our TTE700 performance turbocharger based on the original turbocharger to new higher output specification. Offering an upgrade power upto 700PS
Engineered & Enhanced
At the core of our TTE700 is a much larger TTE compressor wheel, chosen because it is highly efficient and creates an extremely high flow for comparative size. Re-Profiled compressor cover to optimised tolerance to ensure maximum compressor efficiency is given.
We CNC mill the exhaust turbine housing to accept a larger turbine and shaft.
Special profile 360 deg high-performance motorsport journal bearing is fitted, to remain durable at higher loads with no loss in transient response. The actuator used is sprung OE unit
Equilibrium
Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with a serial numbered balance test result document.
Product Highlights:
• Over 600PS on 98ron
• Original BWTS turbocharger as base part
• Thermally shielded exhaust housing and manifold
• Very early response
• Billet Milled TTE compressor
• Reinforced BWTS TTE actuator
• High Flow Turbine
• O-ring sealing
• Reinforced axial and radial bearing
• Proven TheTurboEngineers quality
• Made in Germany
TTE700 with & Unitronic software bundle: https://tteglobal.co.uk/audi/rs3/8v...evo-software-ecu/tcu-bundle?number=TTE10348.1
TTE700 : https://tteglobal.co.uk/audi/rs3/8v.2-2.5-tfsi/33/tte700-evo-upgrade-turbocharger?number=SW10032
Sharp-motorsport Upgrade Injector set required for max output. Link bellow
https://tteglobal.com/audi/rs3/8v.2-2.5-tfsi/186/sharp-motorsport-upgrade-injector-set
Our TTRS 8S 102 RON, 34 deg ambeint temps
Equilibrium
Product Highlights:
• High Flow Turbine
• O-ring sealing
• Made in Germany
