TTE480 Upgrade Performance Turbocharger VAG 2.0 TSI TTE480 begins as a brand new standard BorgWarner K04-064 turbocharger that we dismantle and then set about upgrading and optimizing as engineers to create our ultimate K04 frame hybrid for the EA888. TTE480 Turbocharger is great power stage for the 2.0 TSI range of vehicles while retaining like OE fitment. Engineered & Enhanced The formula to making a TTE480 starts with a much larger 2871X TTE billet compressor wheel, chosen because is highly efficient, new generation type with very thin blades, creating an extremely high flow for comparative size, giving a compressor map that's very wide. The Re-profiled compressor cover is machined to an optimized tolerance to ensure maximum compressor efficiency. We blank of the original PCV port as not required and fit our TTE smooth flow optimized billet blanking plate cover. The intake pipe is CNC ported and hand finished with the TTE smooth flow cover fitted to give a smooth tract and transition for the incoming air for the ultimate flow. We also fit our Billet CNC TTE Boost adapter & silencer delete. Removing any restriction so improving the flow and enhancing the sound. We CNC mill the compressor cover to accept our CNC Billet TTE Recirculation Valve Adapter to fit an Original VAG Recirculation valve to give OE like fitment with trouble-free operation. A key part to driving the large 2871X compressor and in turn making this unit produce the huge power advantage over stock is machining and fitting a far larger 9 blade High-Flow turbine and shaft, while still keeping the k04 core, this is not so easy to do. This large turbine gives much lower back pressure and keeps EGT lower compared to stock K04 turbine or clipped stock. With this TTE stage we have CNC ported the exhaust manifold as standard at the head flange to match and smooth the transition from head to exhaust runner for maximum gas speed and so improving efficiency to the much bigger monster turbine and so driving the compressor harder. Special TTE developed in-house 360 deg high-performance motorsport journal bearing system is fitted. Durable at high loads with no loss in transient response. The actuator used is uprated sprung OE unit, fitted with our reinforced clamps for trouble-free operation. Equilibrium Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document. Key Points: Genuine BorgWarner Housings, Exhaust manifold & Components TTE 2871X Billet Highly Efficient Next Gen Compressor Geometry Optimized Compressor Cover Machining Clearances TTE CNC Billet Smooth Flow Optimised Intake Port Cover Blanking Plate VAG Genuine Original Recirculation Valve Included (latest generation) Genuine OEM Pierburg N75 Valve CNC Ported Hand Finished Intake CNC Billet Direct Recirculation Valve Adapter & Port CNC Billet Boost Adapter & Silencer Delete TTE 9 Blade High-Flow Turbine Genuine BorgWarner Uprated & Reinforced Actuator Special TTE Reinforced Bearing System Fitment As Original. Plug & Play Dynamically Balanced 480 PS Capable Designed, Machined & Built by TTE in Germany Fits bellow : A3 (MK2) / Q3 / TT (MK2) / Beetle / CC / EOS /GOLF / GTI (MK5 / MK6) / Jetta / GLI / Bora / Sigitar (MK5 / MK6) / Passat (B6) / Scirocco / Tiguan / Altea / Leon (MK2) / Toledo (MK2) / Yeti / Octavia / VRS (MK2) / Superb (B6) Engine Codes: CAWA, CAWB, CBFA, CCTA, CCTB, CCZA, CCZB, CCZC, CCZD, 1.8 TSI BZB, CDA Prices: https://tteglobal.com/seat/leon/mk2-2.0-tsi/18/tte480-tsi-upgrade-turbocharger Reconditioning price shown is based on overhauling and reconditioning, upgrading an undamaged used as new turbocharger within specification. Only once cleaned and dismantled, inspected then a firm price be made.
Introducing Our Latest Development for the TTE480 Upgrade Hybrid Turbocharger TTE 9 Blade High-Flow Turbine for the TTE480 VAG 2.0 TSI (Prices to remain the same on current TTE480) Price to Upgrade & Fully Recondition an older TTE480 or TTE420 to this new Spec : 755.46 euro NET + shipping #TTEPOWER #HIGHFLOW #TFSI #TSI #VWGOLF6R #AUDIS38P#CUPRAK1 #VWGOLF6GTI #9BLADEORNOTHING #TTE480
Lightweight VW Golf MK2 Racing equipped with a CDL engine + a DQ250 Gearbox DVX performance België Result : 465.3 HP / 575.0 Nm ✅76% HP↗ ✅64% Nm↗ - CDL Engine - TTE480 turbo 9-blade - Custom Exhaust - Custom Intercooler - Custom Air intake - HPFP upgrade - LPFP upgrade - Upgrade Injectors - Custom DVX Engine Remap (reduced power for track use) - Custom DVX DQ250 Remap ✔600nm torque limiter ✔Raised clamp force ✔faster shift speed ✔faster reaction time shift paddles ✔Kickdown removal in manual mode ✔Shifts at higher rpm 98 octane + 8% Ethanol: 465.3 HP / 575.0 Nm http://dvxperformance.com ☎ 0032 (0) 3 866 32 35 ✉ info@dvxperformance.be #dvxperformance #TTE480 #ttepower
What is critical EGT for TTE480? My tuner is working on my car now and we are faced to high EGT on 400hp about on 100RON without WMI.
Any pictures ? TTE480+ Can handle 1000+ C like an OEM K04-064. Key point to seeing safer lower temps is backpressure after the turbo.
I use greddy gauge, not electronic logging device for EGT. Thank you for temperature limit and advice about backpressure.
I ask as want to understand probe location. During beta testing of the turbocharger we fitted EGT sensor also but did this in the manifold before turbo.
Well, I don't have the photo, but it is placed here: We will try to remove 200cel Magnaflow cat and vibrant resonator from the downpipe and will tune the car.
VW Sicrocco TTE480 TSI Forged engine Milltek Exhaust Revo intake Revo intercooler 70mm throttle body S3 8V injectors HStuned Stg3 ECU & TCU 98ron fuel & WMI 28Deg temps 4xxHp 2.2-1.8bar 100-200 7.40 P-GEAR
@Jefftwitch VW GOLF GTI TTE480 TSI hybrid Forged motor 2.1-1.85bar 102 Ron pump Result 480PS 544Nm #TTE480 #RUNTTE #TTEPOWER
