TTE420 Build Prep, any suggestions and advice?
isimpoi
Newbie
So I'm beginning my TTE420 build on my 2011 Audi S3 8P
Hardware needed:
Runner Flap Delete (Ordered)
LPFP In tank A35HV (Ordered) Possibly change to TSI Basket to make it fit
RS4 Return Fuel Valve (Ordered)
RS3 Injectors
TTE420
I'm aware just chaging the LPFP can have issues on hard cornering and causing issues with the controller but the car won't be track driven and also using Rick's @ UnicornMotorDevelopments custom mapping and I believe he's managed to map cars in with no need for the external Torqbyte controller but may be wrong?
Any other suggestions or hardware people would recommend for going TTE420 build?
S3Alex
Rarely neutral
Gold Supporter
Hardware needed:
RS3 Injectors
TTE420
I think for what you have in mind,Rick is the man to see.
You aren't looking for a whole BT conversion and all the baggage that goes with that,and your list will work fine,assuming you've already done the brakes and suspension.
isimpoi
Newbie
Yea I beleive he will fit my needs best, I won't be using him directly but using a garage in Northumberland called ECM Tech who are a dealer of Rick / Unicorn Motorsport Developments since it's far closer to me up in Scotland.
Basically aiming to get the most out of standard internals and gearbox so TTE420 is best for my goals
Suspension yea, brakes... kinda. Just threw on some better brake pads and drilled and grooved discs
S3Alex
Rarely neutral
Gold Supporter
You will need those!
You won't have any problems with engine internals on that turbo,and it will make a big difference to the way the car feels.
isimpoi
Newbie
I may look into brakes but tbh I won't track the car and with switchable maps will be running lower power going to and from work 90% of the time. Mainly just 1/4 mile the brakes will have a "hard time" so to speak.
Yea I'm not going to the extent of Liam with his 530bhp S3 that's for sure haha. I loved his car when it was running the TTE420 and scary to see the cars it was beating down the quarter mile. DSG obviously playing a big part
S3Alex
Rarely neutral
Gold Supporter
I'm looking to get beyond 550bhp shortly and also get the DSG conversion done.
Do look into the brake aspect as you may be surprised.
I found the brakes pretty marginal at Stg2+ but maybe I use them a bit harder.
Switchable maps are very useful.
My clutch has finally had enough after 4yrs and over 450lbs daily and I can't tell you how bad 1bar feels. Lol
mechanic69
Gold Supporter
Think the RS4 valve is 135bar, need a 155 bar valve for TTE420. 160 from PSI tuning
leshkin
Hold my beer...
From what I've read, fuel return valve requirement will depend on the map. I think I remember Rick saying that a RS4 valve is fine on his maps.
I'm not sure that RS3 injectors are needed with this turbo too.
Sent from a mobile device, please forgive typos :)
isimpoi
Newbie
It's a balance between pressure and injector size. The later is always preferable
Rick
Im using your dealer in or near Northumberland so as long as you think the above is a good balance then im all set haha. May PM you about something ive seen but not sure if you've ever experimented with mapping wise
