AUDI RS C7 4.0 TFSI TTE1000+ UPGRADE TURBOCHARGERS Introducing our TTE1000+ Turbo upgrade stage for the AUDI 4.0 TFSI. For the production of the our AUDI RS C7 TTE1000+ upgrade turbochargers, TTE uses light weight milled compressor wheels with big open flowing exhaust turbines and upgrade exhaust manifolds. These cast and heat shield thermally isolated upgrade exhaust manifolds have significantly larger runners than the series parts, therefore promote significantly more gas flow to the turbines. The standard OEM compressor and exhaust housings are machined with a CNC milling machine so that they can receive the new larger internals. Feature Genuine IHI Housings & Components TTE Highly Efficient Next Gen Billet Compressor Geometry Optimized Compressor Cover Machining Clearances TTE Special 9 blade turbines High-Flow Low-Mass Upgrade cast exhaust manifolds with TTE thermal isolation Uprated & Synchronized actuators Fitment As Original Single parts finely balanced then components assembled and core high-speed VSR balanced Supplied with a balance test result document Proven TheTurboEngineers quality Designed for 1000+ HP Made in Germany MORE INFO HERE
