Hi all, bought a TT today but didn't realise it doesn't show you the distance or anything to the object that's causing the beeping. I've seen I can change the beep volume but can't see anywhere to turn the visual on in the settings and I've read on here you need to add code with the vcds so could anyone help? South Wales area. Thanks
Hi Jeff, I bought a OBDeleven device from https://obdeleven.com/en/. Cost me just over £80 for the pro package, plugs into the car connects to your android phone via bluetooth and gives you a bunch of one click options to add/remove features such as the reverse visual display on the MMI, really easy and worked perfectly for me. Had it delivered yesterday, turned on the reverse visual display for the sensors as well as the passenger mirror dipping when you put the car into reverse. Worth checking out
Hi Alex. That sounds good. I have the dipping reverse mirror working. Would you turn on my reverse visual display for a fee for your time?
