  2. Dismiss Notice
Transportation blocks?
A4B9 Jul 25, 2016
  1. A4B9
    A4B9 Well-Known Member
    520
    270
    Just noticed this orange piece on my rear suspension - is it a transportation block?
  2. Avatar
    snack-media
    Advertisement
  3. cuke2u
    cuke2u Well-Known Member
    12,823
    5,222
  4. f1nny
    f1nny Active Member
    326
    159
    43
    I have the same orange piece on my suspension. It seems to be a normal part of the suspension. Parts catalog names it as a "helper spring"
    Item 7 below
  5. cuke2u
    12,823
    5,222
    In looking at your illustration f1nny I would say that transportation blocks would be fitted under item 6 to stop any movement. Item 7 looks like it could be either a stop or a rebound buffer...
    f1nny likes this.
  6. A4B9
    520
    270
    Is the ride height affected by the transportation blocks? Does it look a bit too high on that photo?
    I've compared mine to relatively new Audis (mainly A1s and A3s) and none are as high as mine
  7. Daggerit
    Daggerit Well-Known Member
    3,184
    1,627
    Could you just apply some pressure to the car to see if the springs have any give? i.e. bounce the car up and down with your hands? I imagine if the transport blocks were in then it wouldn't really move much if at all.
  8. cuke2u
    12,823
    5,222
    What suspension have you got, size of wheels and is yours a se, sport or sline?
  9. A4B9
    520
    270
    Adaptive comfort suspension, 18s and it's an s-line
  10. cuke2u
    12,823
    5,222
    Adaptive comfort suspension has a ride height 20mm higher than the standard sports suspension normally fitted to a sline so it might look higher. To be honest if the ride isn't knocking out your fillings, as it would be rock hard with the blocks in place, then I wouldn't worry.
