I have a 2005 1.8t s line cabriolet.
Mot is due next month and my pre inspection turned up a couple of issues on the front track control arms.
I have a split ball joint cover on the front lower arms on both sides but bushes are good.
The lower rear arm on one side is a aftermarket d2p part and has a lot of movement in the rear Bush so needs to go.
All four upper arms are starting to show splitting of the bushes with some movement.
Onto the questions. Can the lower front arm ball joint covers be renewed and if so what size covers do I need to order.
If the covers can't be replaced I am thinking of renewing all the arms in one go. I have seen kits for various prices and of very differing quality. Can anyone recommend a particular kit and has anyone had any experience of the skv kits on Ebay. Are they too cheap to be worth the effort.
The final item is the rear upper control arm outer bushes on the rear axle. I am aware the subframe needs to be lowered to replace the arm but how difficult is the outer Bush to replace with the arm in situe. I would be looking to wind the bushes out and wind replacements back in.
