Guys i have just fitted a tow bar to my 2010 a6 avant. looking for some help on the electrics as i have a bypass relay wondering where to connect the wires to . I think this is the control module for the rear light would i be correct ?. Would anyone have a wiring diagram for this as i am at a loss with what to connect up . Any help would be great.
#NumberDescriptionQty. list of uses; control unit 1control unit for access and; start authorisation; see illustration:; 909-00 2control unit for tyre pressure; control; see illustration:; 907-50 3engine control unit; see illustration:; 906-00; petr. engine 3engine control unit; see illustration:; 906-05; diesel eng. 4control unit for automatic; headlight range control; see illustration:; 941-25 5onboard supply control unit; see illustration:; control unit 2; 907-00 7cd changers; see illustration:; 035-38 7connection for external; audio sources; see illustration:; 035-38 7chip card reader for road; toll system; see illustration:; 035-57 8interface box with software; see illustration:; 'MMI'; 919-10 9control unit for special veh.; see illustration:; 907-20 10display and control unit; for multimedia interface 'mmi'; see illustration:; 919-00 10sender and receiver unit; for road toll system; see illustration:; 035-57 11door control unit; see illustration:; right front; 959-10 12control unit for movement; sensor; see illustration:; 951-40 13control unit for memory seat; and backrest adjustment; (passenger side); see illustration:; front; 959-20 14door control unit; see illustration:; right rear; 959-10 16control unit for parking aid; see illustration:; 919-20 17control unit for trailer; detection; see illustration:; 945-50 17control unit for; reversing camera system; see illustration:; 907-40 17interface control unit; for vehicle location system; see illustration:; 907-31 17amplifiers; for vehicles with cellphone; preparation; see illustration:; 035-55 18control unit with software for; electromechanical parking; brake -epb-; see illustration:; 615-60; PR-1KD 18control unit with software for; electromechanical parking; brake -epb-; see illustration:; 615-65; PR-1KW 19central control unit for; convenience system; see illustration:; 907-00 20control unit for battery; monitoring; see illustration:; 915-00 21receiver for radio-wave clock; see illustration:; 920-00 22amplifier for sound system; see illustration:; 035-43 23navigation unit with soft; ware; see illustration:; 035-07 24tv-receiver (tuner) with; software; see illustration:; analogue; 035-07 24tv-receiver (tuner) with; software; see illustration:; digital; 035-45 24amplifier for sound system; see illustration:; 035-40; PR-8YQ,8AJ,; 8DN,8DP+8RY 24amplifier for sound system; see illustration:; 035-41; PR-8D2,8DY,; 8DS+8RY 25control and receiver unit with; software for car radio; see illustration:; 035-43 25control unit for digital; radio reception; see illustration:; 035-45 25radio unit; see illustration:; 035-40; PR-8YQ,8AJ,; 8DN,8DP 25radio unit; see illustration:; 035-41; PR-8D2,8DY,; 8DS 26voice module with software; see illustration:; 035-43 26receiver unit for; tv reception; see illustration:; 035-40; PR-QU1,QV9 26receiver unit for; tv reception; see illustration:; 035-41; PR-QV2 27control unit for auxiliary; heater; see illustration:; 819-70 27Acontrol unit for fuel; pump; see illustration:; 919-30; frt.-wh.dr.+; PR-A8S 27Acontrol unit for fuel; pump; see illustration:; 919-32; frt.-wh.dr.+; PR-A8U 27Acontrol unit for fuel; pump; see illustration:; 919-35; quattro 28door control unit; see illustration:; left rear; 959-10 29control unit for memory seat; and backrest adjustment; (drivers side); see illustration:; front; 959-20 30control unit for airbag; see illustration:; 959-30 30interface box; for vehicles with preparation; for telephone; see illustration:; 035-57; "J.." 31door control unit; see illustration:; left front; 959-10 32control unit for telephone; see illustration:; 035-50 33interface box; see illustration:; 'HANDY'; 035-56 34electronic module for steering; column combination switch; see illustration:; 'SMLS'; 953-50 35control unit; control unit for electronic; steering column lock; see illustration:; 419-50 35control unit for vehicle; authorisation system; see illustration:; 419-50 36onboard supply control unit; see illustration:; control unit 1; 907-00 37relay plate and relays; see illustration:; 937-00 37relay plate and relays; water box; see illustration:; 937-20 38abs unit with control unit; see illustration:; 614-10 39control unit; auxiliary heater; see illustration:; 819-70 40combi-instrument; see illustration:; 920-00 41wiper motor with control unit; see illustration:; 955-00 42ignition/starter switch; see illustration:; 909-00 43display and control panel with; cu for electronically; controlled air-conditioning; see illustration:; front; 820-00; PR-9AK 43display and control panel with; cu for electronically; controlled air-conditioning; see illustration:; front; 820-10; PR-9AQ 44control unit for 6-speed; automatic gearbox; see illustration:; 325-80 44control unit for automatic; transmission - infin. variable; see illustration:; 927-50 45diagnosis interface for; data bus (gateway); see illustration:; 907-00 45control unit for infor-; mation electronics; see illustration:; 035-00; PR-8YQ,8AJ,; 8DP 45control unit for infor-; mation electronics; see illustration:; 035-05; PR-8DY,8DZ 46control unit for; distance regulation; see illustration:; 907-05 47control unit for adaptive; suspension; see illustration:; 616-30 48control unit for; opening garage door; see illustration:; 907-05 #NumberDescriptionQty. switch - brake light; switch for clutch; pedal; socket; control unit for trailer; detection switch - brake light 14F0945459Bbrake light sensor; 4 pin1 -switch for clutch; pedal; see illustration:; 721-25 socket; for models with; towing facility; PR-1D4 68K0945505housing for trailer towing; socket; 13 pin1 77H0971978rd. connector sleeve housing; 13 pin1 81C0945527cover with grommet1 9N 01100518hexagon nut; M53 10N 10680601hexagon socket flat; head bolt; M5X303 117H0972217Cannular contact w/ solder pinX control unit for trailer; detection; PR-1D4 154F0907383Dcontrol unit for trailer; detection1 16no replacement part for; this model 176Q0937713flat contact housing with; contact locking mechanism; 16 pin; black1 186Q0972883Bflat contact housing with; contact locking mechanism; 12 pin; red1 -retainer for control unit; see illustration:; right rear; 907-10
You need to know what you have....wiring a control or trailer detection module will be completely different from wiring a bypass relay. Trailer detection modules should come with installation instructions. Bypass relays are generic and you should be able to find wiring info online.
I have a bypass relay and a bag of scotch clips that came with it. I was just looking to see if i could find a wiring diagram that shows which wires run to the lights from the control module and i could connect the scotch clips to them.
Hi This link will give you all you need http://www.rydertowing.co.uk/vehicle-data/sheets/audi/a6-all-2004-2010
Hi Andy I have just installed my bypass relay using the information from above link. It was a lot easier to do than I thought. All the connections you need are behind the right hand side cover in the boot. There is a block connector which has all the wires you need including the left hand indicator, there is a power there which you can take a fused power from (mine was the brown plug) Happy wiring
Can you point out the block connector you refer to? I'm about to wire a relay module to my 2010 A6 C6 Avant and the more info I have beforehand the better!
I just used the kufatec loom as it was easier and keeps it all OEM as some of the relay bypass don't work 100% with functionality and register with car .as your car changes certain aspects when towing engaged ... Also if you pdc sensors most relay bypass don't work correctly with the towing
