  2. Dismiss Notice
Totally a newb 2001 2.4 V6 exhaust and many other questions
Daggz68 Feb 25, 2020
  1. Daggz68
    Daggz68 New Member
    17
    Hi all. I'm more a VW and the biggest lump I've had in those is the 2.3 v5 150 in a Bora. Had a classic 2.2 Audi Coupe s E reg and some pile of rubbish 80 off a mate years ago.
    My question relates to the exhaust, satnav and display ( for now ;-) )
    Before the cat, is there a flexi joint as it sounds like it's blowing from there badly. Anyone got a diagram of the system to check out?
    The satnav doesn't pick up where you are. The antenna on the rear of the roof ( estate ) has a naff little aerial fitted. This does pick up fm. Been told the stereo also has TV, but guess that's a different aeriel plus adapter needed?
    Also the display for I'm guessing fuel consumption etc is stuffed. Lights up, with lines across it. Can that be repaired or need a new set dials?
    Sorry for the questions!! :)
    Gary[​IMG]
    Sent from my VTR-L09 using Tapatalk
  2. Avatar
    snack-media
    Advertisement
  3. stevey83
    stevey83 Active Member
    219
    27
    GPS aerial is under the dash on a standard fit system, above the glovebox. What headunit is it?Mine had the satnav and tv option, but was so old it could only pick up analogue, which is now long dead.
  4. Daggz68
    Daggz68 New Member
    17
    This one[​IMG]
  5. Ricky Burrows
    Ricky Burrows Well-Known Member TeamMisano TFSI Owners Group saloon Audi A4 S-line owners group Manual
    1,391
    669
    If you take out your dials there are companies around that will fix the pixels so it can definitely be repaired, you just have to find someone that can do it, i think its no more than £150 to repair.
    Daggz68 likes this.
  6. stevey83
    219
    27
    Yeah same as mine, ditch it!
    Daggz68 likes this.
  7. Daggz68
    Daggz68 New Member
    17
    I can pretty much buy any cheap Chinese headunit with satnav or screen share off my phone, but what else is needed. Has the Bose system.
  8. quattrogone
    quattrogone Quattro Back!
    248
    93
    I think you'll find it more of a mare because it's got bose..
  9. Daggz68
    Daggz68 New Member
    17
    I'm sure there's an adapter to go between the normal speaker wires and the amp. Just not sure which one on ebay
  10. stevey83
    219
    27
    Daggz68 likes this.
