Hi I want to clean the maf with electrical cleaner and a cotton bud, but can't get to it! I've removed it connected to the plastic tube, but can't remove the meter using anti tamper torx heads. What tool is it ? Dave
The screws for the maf housing aren't torx heads, I believe they are 5 spline not 6. I used a flat blade screw driver when I took mine out to clean it.
You can get a 6 point torx to fit if you file off one point completely and then trim the oints either side of the one you filed off. This is what I had to do to get the MAF out of my Passat. used the bit several times before it broke. Karl.
Doh, thought you had made it super accurate with a dremel ! Another fail, choo choo, all aboard the fail wagon Dave
