Tuesday,14,May,2019,15:58:14:06850
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.4.0.0 (x64) HEX-V2 CB: 0.4504.4
Data version: 20190411 DS307.0
www.Ross-Tech.com
VIN: WAUZZZ4GXCN168984 License Plate: MY-SCAN
Mileage: 234666km-145814mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 20 22 28 34 36 3B
3C 42 44 46 47 52 53 55 56 57 5F 62 69 6C 6D 72 82 84 85 88
89 8B 8E 8F 90 A9 C0
VIN: WAUZZZ4GXCN168984 Mileage: 234666km-145814miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
84-Night Vision -- Status: OK 0000
85-On Board Cam. -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: OK 0000
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 49B7C70192EDE380EB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3828D8DAB2D227E747B-806C
8 Faults Found:
0732 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SCL_QSP_Ist_Moment_Error]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:39:12
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: 04
Uz: BE
0511 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SCL_SARA_Accel_X_010_NotCalibrated]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:39:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: EE
Uz: BE
0513 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SCL_SARA_Accel_Y_010_NotCalibrated]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:39:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: F2
Uz: BE
0806 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_SARA_Accel_Y_b_red_Invalid]
MIL ON - Not Confirmed - Tested Since Memory Clear
0741 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SCL_SARA_Accel_Y_b_red_NotCalibrated]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:39:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 1B
Uz: BE
0515 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SCL_SARA_Omega_Z_010_NotCalibrated]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:39:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 4F
Uz: BE
0807 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_SARA_Omega_Z_b_red_Invalid]
0742 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SCL_SARA_Omega_Z_b_red_NotCalibrated]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:39:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 1F
Uz: BE
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 R HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0045
Revision: -------- Serial number: 56261208802435
Coding: B92B08
ASAM Dataset: EV_EPHVA2CAU57X0000 002011
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 41DEB53EE108662FF05-8014
1 Fault Found:
13637413 - Databus
U1123 00 [009] - Received Error Message
[Bremsensteuergerät - ESP_01.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:31
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Serial number: 00000000000000
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 2808089A6272B767D7B-807C
4 Faults Found:
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VDC_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
Control Module temperature: 23 °C
Voltage terminal 15: 14.641 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
134656 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_AXV_ADJUSTMENT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
136192 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_YAW_ADJUSTMENT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VIDEO_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H15 0013
Serial number: 000604120001010
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 270A0BA66F6CB81FDE1-8072
6 Faults Found:
0377 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[ESP - Steuergerät nicht verfügbar DTC_FRAY_ESP_SYS_STATE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
0370 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_03_CF_YAWRATE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
0373 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_03_CF_CROSS_ACC]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
0359 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_YAWRATE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
0363 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_CROSS_ACC_X]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
0366 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_CROSS_ACC_Y]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008003
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E04FE824096E9571D7-807A
6 Faults Found:
403200 - Function Shut-Off Active
C10C8 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:47:07
0920 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:47:07
0666 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:47:07
0665 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:47:07
0769 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:47:07
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:47:17
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E01894.
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372ADBE6BFCC289F4E1-8062
1 Fault Found:
5242880 - No Basic Setting
B2010 00 [009] - -
[ECU not vehicle based calibrated]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
DCU_Internal_DTC: 50 00 00
Ignition Cycle Count: 17000
DCU Temperature: 31 °C
Voltage terminal 30: 14.6 V
Voltage VBG 22: 2.5 V
VIN received: WAUZZZ4GXCN168984
Debug Data: 00 00 00 00 00 00 00 00
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000311388
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0CF2927C7E8577C1F-807E
1 Fault Found:
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:47:29
Voltage terminal 30: 14.8 V
Internal Fault ID: 185
Vehicle speed: 0 km/h
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: On
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Revision: -------- Serial number: 262130025421000
Coding: FA060000
Shop #: WSC 02485 349 00001
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 261406A26866A117E57-8072
2 Faults Found:
0730 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SARA_SARA_04_Signal_error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:33
Outside air temperature: -42.0 °C
Voltage terminal 15: 14.4 V
Control Module temperature: 36.0 °C
0773 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SARA_SARA_05_Signal_error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:33
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
3 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
Control Module temperature: 18 °C
Voltage terminal 15: 14.628 V
Velocity_vehicle_reference: -0.00 m/s
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
Control Module temperature: 19 °C
Voltage terminal 15: 14.649 V
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000051604127
Coding: 04C0BB1E1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
5 Faults Found:
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[ESP_ESP_01_Signal_Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
Outside air temperature: 16.5 °C
Voltage terminal 15: 14.5 V
Control Module temperature: 27.0 °C
0057 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SARA_SARA_01_Signal_error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
0116 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SARA_SARA_02_Signal_error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
0165 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[QSP_Signal_Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:32
0091 - Function Limitation due to Missing Video Data
C1108 00 [009] - -
[DPC_SystemError]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 234666 km
Date: 2019.05.14
Time: 15:37:33
Voltage terminal 15: 14.6 V
End----------(Elapsed Time: 03:05, VBatt start/end: 14.8V/14.8V)-----------
