  2. Dismiss Notice
Toe & Camber Bolts
jarnold231 Jul 24, 2020
  1. jarnold231
    jarnold231 Active Member
    208
    150
    43
  2. Avatar
    snack-media
    Advertisement
  3. Pie-eyedpiper
    Pie-eyedpiper Well-Known Member
    601
    263
    Do you know, I've just had mine apart today when doing a rear spring. The near side isn't in very good shape so I'm going to replace. But I've found this, and from the measurements it's the same as my rear control arm bolt.
    A lot cheaper than the kit you posted too.
    https://www.ebay.co.uk/itm/282540148451
    jarnold231 likes this.
  4. jarnold231
    208
    150
    43
    Assuming they're all the same that would come in at £41.80 - so much better deal
  5. Pie-eyedpiper
    601
    263
    Where are the toe bolts in the car? I can't tell from the parts diagram that Rob posted.
    My off side camber bolt isn't shifting, it's seized in the control arm bush.
    I've got 2 new control arms and bolts on order and will and up cutting through the bush. I just hope the inner control arm bolt comes out, or that is a cut job too.
  6. Pie-eyedpiper
    601
    263
    @ I'm Just Rob, on your original parts list (linked to) do you know the size/part number or the rear control arms inner bolt?
    Your drawing doesn't quite include it., And I might need them.
