  2. Dismiss Notice
Today's dyno results
Oranoco Oct 28, 2016
  1. Oranoco
    Oranoco Registered User
    4,026
    417
    Well as we had the dyno at our disposal it would have been rude not to get some pre tear down figures.
    245bhp and 270ft/lb torque
  2. Avatar
    snack-media
    Advertisement
  3. EvilSnow
    EvilSnow Registered User
    596
    33
    What set up was this?
    Sent from my SM-G920F using Tapatalk
  4. aragorn
    18,710
    909
    K04-020 from an S3, modified to fit the A4.
    It got a bit lean at the top end, whats going on there? Somethings become maxed out!
  5. Oranoco
    4,026
    417
    Undecided whether the current K03/K04-023 ******* turbo will be stripped and reconfigured or whether we look at something else entirely.
    There was no det but it ran lean at the top and in all honesty we're not sure why. Injector duty cycle is at 80% (I think my bro said) so not excessive. Further investigation is needed but for 190,000 miles I don't think I have cause for complaint.
  6. Oranoco
    4,026
    417
    Spec is currently;
    K03/K04-023 love child
    C20 LET injectors
    3bar FPR
    Golf VR6 MAF housing (new stock sensor)
    Evolution RaceWerks TIP
    Front mount intercooler
    HKS rip off mushroom filter
    Custom chip file 22psi
  7. EvilSnow
    596
    33
    Figures are still pretty good though man give yourself some credit
  8. Oranoco
    4,026
    417
    I'm chuffed to be honest for the mileage and beating it's endured. Almost 100bhp up on the standard car isn't to be sniffed at.
  9. EvilSnow
    596
    33
    What's the spool/pull like through the gears?
  10. Oranoco
    4,026
    417
    It actually spools up quite briskly and the torque comes in quite hard. Great fun on track.
  11. aragorn
    18,710
    909
    If its not injector duty, then it can only really be the fuel pump?
    There has to be more in that turbo, your boost tails off when it really should be able to hang on to it a bit further up the revs. Did you get any logs of N75 duty cycle? I think if your sticking with the K03 housing, theres no point going bigger than what you have. Get a stronger actuator on it and push the boost up to 1.5bar held and you'll probably match what my much bigger, laggier K300 hybrid is doing.
    The bonus being that if the turbo does ever fail, you can simply buy a new standard K04-020 and swap it in.
    If you do want more, then K04-063 or a Garret GTX2860R is what i'd be looking at.
  12. Avatar
    snack-media
    Advertisement
  13. Oranoco
    4,026
    417
    We didn't log the N75 but my brother did suggest a more sturdy actuator and fuel pump is on the list anyway.
    This car is going to be Trigger's broom lol
  14. Broken Byzan
    Broken Byzan Photographic Moderator Staff Member Moderator VCDS Map User
    13,224
    470
    afr 13:1 is acceptable imho. Am i reading it wrong? Ok it's less than ideal, but not melty lean yet
    Ive paid a lot more for a lot less power thanks to MRC and the crappy map. good work. Any more, i'd get rods tbh
  15. Oranoco
    4,026
    417
    13.1 is quite lean at WOT really want it about 11.9.
    Rods are being done and have a set in the kitchen ready to go in. Seemed silly not to do them really
    Samuel c5 Q likes this.
  16. aragorn
    18,710
    909
    12.5 is fine, down in the low12's high 11's is probably costing you power. As mark says, its not mega bad, but the shape of the curve clearly shows somethings run out of capacity.
    I'm at 295lbft on stock rods :p Its simply not worth the cost.
  17. Oranoco
    4,026
    417
    I'm just not brave enough to push the stock rods at the mileage on them and the steel rods are already here so no huge extra drama to pop them in.
    Any actuator suggestions?
  18. aragorn
    18,710
    909
    Mines on 170k miles. For the cost of fitting rods and the associated rebuild parts i could buy a V8 or a 2.7T, either of which would give a significantly better end result. Thus its getting driven on stock engine. If it blows up, i'll need to go hunting for a V8 :p
    My actuator is a cheap chinese 12psi thing, bodged up to fit.
    I'd maybe suggest a good olde ford -31?
    8psi should give a bit more control than a 12psi one like i've got.
  19. Oranoco
    4,026
    417
    To he honest I just can't be bothered to do an engine swap but acknowledge what you say.
    Probably have a -31 from my RS Turbo laying about in the garage so will have a play with that.
  20. Oranoco
    4,026
    417
    Tear down has started and already found a split hose between the N75 and actuator, a number of oil leaks and the turbo is pretty goosed with loads of play in the shaft and the compressor wheel being able to touch the housing. Unsure if I should have the existing unit overhauled or whether I should look at something else altogether.
  21. Broken Byzan
    13,224
    470
    a replacement core is cheapest option as you have machine work already done
  22. sam80quattro
    sam80quattro Registered User
    149
    a 4 bar fpr will add more fuel :D
    310ftlb on my stock aeb (unkown mileage) same fueling setup as above (other than 4bar fpr) and a kjet fuel pump (its in a 90quattro) with a t28
  23. Oranoco
    4,026
    417
    Well not all bad news, the block has come back with a clean bill of health and requiring no work. Cylinder head needed new exhaust valve guides but the cams again are fine. Just waiting for all the bits to be returned to the workshop and it can all start going back together.
    Certainly can't complain at the build quality.
    Cheers Sam, 4 bar FPR is sat here in my spares box.
  24. aragorn
    18,710
    909
    personally, i would keep it on 3 bar and fit larger injectors.
    4 bar regulator just stresses the pump more and reduces its flow capability.
  25. Oranoco
    4,026
    417
    Fitting a new beefier pump seeing as it's this far apart :) seemed silly not to really. probably going to stick a set of VXR injectors in as the 550's are a bit OTT really
  26. Oranoco
    4,026
    417
    Starting to come back together at last, well it's bits are mostly in the same place.
    Block is back and despite the miles wasn't in need of a rebore. Head needed some faff as the timing chain tensioner was knackered as were the exhaust valve guides.
    New rods mated to original Mahle pistons which were given a clean bill of health.
    And the new turbo which should be sufficient for 280-300bhp. The builder spec'd and built the unit knowing it was going to be run up by a dyno manufacturer. I don't know the spec myself yet so can't reveal much.
  27. aragorn
    18,710
    909
    certainly be interesting to see whats inside the turbo...
    Bear in mind, a completely standard K04-020, in its original home (the S3/TT), with a decent exhaust manifold and all the bolt ons, will already be up in that 280-300 range.
  28. Oranoco
    4,026
    417
    Problem is the A4's manifold isn't all that clever and I've not found a sensible alternative as all aftermarket manifolds seem to crack. Don't want a £300 manifold as a service item
  29. aragorn
    18,710
    909
    Yeh but fitting a bigger turbo to try and get round that doesnt really work. You just end up with the lag and response of a 350hp turbo, and massive boost and manifold pressure trying to force the gasses thru, and still only have 280hp. I know this because thats exactly what my car has :p
    Hopefully they've not gone too silly with it. Bigger turbine to help flow and maybe a K06 ETT wheel of similar size to the original is about as much as you'd want.
    Where did your turbine housing come from?
  30. Oranoco
    4,026
    417
    I would very much like to solve the manifold issue if I can as this seems a not too uncommon gripe.
    Will reveal the turbo spec once I know for sure.
  31. Oranoco
    4,026
    417
    Well it's starting to look a lot like an engine again now.
    Hoping the engine will be back in the bay by early part of next week.
  32. Oranoco
    4,026
    417
    Almost there. Should be back in the bay Monday and driving on Tuesday.
  33. Avatar
    snack-media
    Advertisement
  34. aragorn
    18,710
    909
  35. EvilSnow
    596
    33
    Look good man
  36. Oranoco
    4,026
    417
    Well a solid day of graft with my brother and it looks like a car again and sounds pretty darn nice too.
    Managed to get a couple of miles on it but found a very small fuel leak as a result of pulling it all out to put the beefier pump in. Also need to sort a heat shield out for the filter then crack on with running it in.
    slepy likes this.
  37. aragorn
    18,710
    909
    That filter looks a bit weedy...
    far far better just using the standard airbox. Stick a panel filter in if you must. but the stock airbox is good for well over 400hp.
    Did you get the specs of the turbo?
  38. Oranoco
    4,026
    417
    Standard airbox won't fit with my MAF and TIP unfortunately as that would have by far been the preferred option. Slightly annoying as I spent ages climbing through the loft and rummaging round the sheds to find the poxy thing.
    Brother has all the paperwork, I just need to collect it all. At the minute we're just trying to get it buttoned up. Will get them up asap though
  39. aragorn
    18,710
    909
  40. Oranoco
    4,026
    417
    Welcome home, now comes the running in fun. had to order a new PCV valve as the old one was dead. Hats off to Awesome, ordered at 2pm and was at my front door by 11am today.
  41. EvilSnow
    596
    33
    Where abouts are you based Oranoco?
  42. aragorn
    18,710
    909
    I ran mine in in about 25miles. ;)
  43. Oranoco
    4,026
    417
    Hertfordshire mate.
