  2. Dismiss Notice
TMU's Glacier White B8.5 S4 - MRC Stage 2
V6_Man Apr 8, 2017
  1. Cerbera9
    Cerbera9 Well-Known Member
    430
    305
    I bet they're fun to fit without lifting out the engine!
  2. Avatar
    snack-media
    Advertisement
  3. Cerbera9
    430
    305
  4. xpoweruk
    xpoweruk TTTS 8J Smile Machine Team Meteor quattro Audi TTS
    2,436
    1,768
    Right hand drive needs a slight dent/adjustment apparently
  5. arad85
    arad85 Well-Known Member Team V6 Audi S5 Black Edition
    1,081
    431
    Knew I spoke too soon!
    Having to have a few bits and pieces removed (back to stage 2) whilst they look at an issue back in the US. As you may know, the new engine has a different supercharger to previously and is driven by a magnetic clutch. It appears to be a weak point on the higher levels of tune so they are not happy with that. Kudos to the team working on it for seeing the issue, and dealing with it properly. I've been impressed with the very long hours worked and honest approach the guys at Awesome/APR UK and APR US have had.
    One to be mindful of on stage 2+ CREC-based engines from other tuners.
    Chop., xpoweruk and V6_Man like this.
  6. V6_Man
    V6_Man Moderator Staff Member Moderator Team Glacier Supercharged TFSI Owners Group Team V6 VCDS Map User Team Scuba Audi S4 quattro Audi A3 Black Edition
    6,910
    13,947
    What I have been struggling to get to is the reason(s) for Cats failure. It seems Tune can be one of the reasons but not the only one. With the links sent above the good thing is that there are more than one replacement options available. And given the size of mod investments everyone has made I'd think we should be fine .
    xpoweruk likes this.
  7. V6_Man
    6,910
    13,947
    One of the things I have definitely noticed is the amount of heat the car now generates, which can be attributed to cats failure, I was thinking of putting an extra cooler in to bulletproof it. Any suggestions on that.
  8. V6_Man
    6,910
    13,947
    And it looks like it is going to be a 6 month project and I would like to do it in the below order:
    1- Exhaust
    2- Supercharger Cooler
    3- Brakes (I might stay stock as I am not doing track days), and
    4- B12 Sportsline
    arad85 likes this.
  9. xpoweruk
    2,436
    1,768
    Merc racing are putting together a heat exchanger package for the S4 over in the US as we speak.It will be very well priced too by the look of it
    V6_Man likes this.
  10. xpoweruk
    2,436
    1,768
  11. V6_Man
    6,910
    13,947
  12. Avatar
    snack-media
    Advertisement
  13. Dippy
    Dippy Well-Known Member Team Monsoon Audi S5 Black Edition
    1,902
    1,305
    I'm interested to know what info you have about this. I have the oil temp reading on my DIS and it doesn't seem to have changed much with my stage 2. My plan was to wait until the hot weather in Summer (assuming we get some hot weather this year) and then see if my car overheats before investing in a cooler.
    My plan was also that if I get a cooler I'd also increase the size of my Vdamper but now that APR has found out that the CREC supercharger clutch will slip I probably have to abandon that plan :(
    V6_Man likes this.
  14. xpoweruk
    2,436
    1,768
    The oil will likely not show any measureable difference because it disipats heat in to the the main coolant circuit via the oil/coolant heat exchanger. Same as the coolant will stay at a steady 94-95*C
    The chargers coolant circuit will show a measureable difference though.An app like torque is needed to see that though
    V6_Man likes this.
  15. V6_Man
    6,910
    13,947
    You are right in that the oil temperature doesn't show any difference as such and although I haven't measured the actual difference using an App like XP has my observation is based purely on the basis of how hot the car feels compared to before the remap. Now I must admit that I do drive like a Ms. Daisy and don't thrash it too much but a little bit that I have done compared to the two drives that I have done since the remap there is a difference in the heat coming out of the engine. But it might be my paranoia. So far, I have relied on my experience of the car rather than any hard statistics. The immediate thing I am going to invest in is an Android phone, an app and an ODBC2 Bluetooth
  16. V6_Man
    6,910
    13,947
    And I have just realised that 'My Company' needs a new Phone and some IT equipment to do my work more efficiently. How can I get to work if my 'IT Equipment' is ageing
  17. arad85
    1,081
    431
    There's probably an equivalent apple phone app.
    V6_Man likes this.
  18. xpoweruk
    2,436
    1,768
    I imagi e the extra heat is from the charger not getting cooled effectively, without extra cooling they get very hot, with cooling you can hold ya ha d on top without issue
    V6_Man likes this.
  19. arad85
    1,081
    431
    There's a reason people sell expensive radiators to put in the front of the car then :)
  20. Dippy
    1,902
    1,305
    Thanks. I have a Ross-tech dongle so I can access engine data with VCDS. Do you know what I need to log?
  21. xpoweruk
    2,436
    1,768
    V6_Man and arad85 like this.
  22. xpoweruk
    2,436
    1,768
    The below graph shows the difference cooling can make
    Chop. and V6_Man like this.
  23. Dippy
    1,902
    1,305
    Thanks XP
  24. V6_Man
    6,910
    13,947
    Both had a shower today. Spent 8 hours on the silver one; 1 Stage correction as by the time I finished it was 8:30. She also had an under-chassis wash and we were both very happy in the end
    Chop., arad85 and xpoweruk like this.
  25. V6_Man
    6,910
    13,947
    I am also planning on taking the silver one to MRC for a remap. It is 140 diesel, multitronic and a little bit power would make it more exciting to drive. However I have also read horror stories about the gearbox. It is Mrs' car and has only done 62k on the clock.
  26. V6_Man
    6,910
    13,947
    Needs some advice. I have been reading different forums, XP and Chop's builds and couple of other guys asking the same question. I want to lower the car just a little bit. Mine doesn't have a Sports Diff and I was thinking about going only Eibach springs along with the swaybar. Do you guys think it would be OK or should I go Eibach Springs along with B12 kit? What is the perfect drop (know it is relative but I like XPs drop). Also, it is 255/35/19.
  27. Chop.
    Chop. Well-Known Member
    1,804
    1,879
    6 hours labour aint bad the down pipes alone are a bitch to change
    V6_Man likes this.
  28. xpoweruk
    2,436
    1,768
    Mines on dropped around 15mm front 10mm rear iirc
    I only had the rear ARB fitted to encourage more oversteer
  29. V6_Man
    6,910
    13,947
    Cheers bud. So Eibach only would do that or I need them along with the B12 kit?
  30. Chop.
    1,804
    1,879
    i suppose its personal prefernce at the end of the day, i just went springs and im happy with the feel on the standard shocks but someone slse going for a 40mm might want to do a full kit
    IMO if your not going for a massive drop ie 20-25mm i'd go just go with the springs
    ( im talking advertised drop not actual drop )
    V6_Man likes this.
  31. xpoweruk
    2,436
    1,768
    Eibach will give you that kind of drop,maybe up to 20mm front 15mm rear
    I like the way the front drops a touch more adding rake & improving turn in
    V6_Man likes this.
  32. V6_Man
    6,910
    13,947
    Perfect. Chop and XP you guys are true legends.
    xpoweruk and Chop. like this.
  33. Avatar
    snack-media
    Advertisement
  34. V6_Man
    6,910
    13,947
    [​IMG][​IMG][​IMG]
    Last night picture didn't do the justice so I thought I'll add some more. The shiny black chassis - and I can sleep peacefully tonight
  35. Chop.
    1,804
    1,879
    get myself or XP round and team chav can cut some holes in your bonnet :screamcat::sunglasses::tongueclosed:
    gary_a4_quattro, arad85 and xpoweruk like this.
  36. xpoweruk
    2,436
    1,768
    Hahaa grinders at the ready :rockwoot:
    Chop. likes this.
  37. V6_Man
    6,910
    13,947
    Hahaha. I don't know how you guys do it. I would be too scared to cut the bonnet. What if ...
  38. V6_Man
    6,910
    13,947
    Right Troops, where can I get in UK this ECS rear diffuser
  39. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    2,039
    822
    Awesome GTI are the ECS importers. If they don't have it on their website ping them an email and they'll put in a special order. Works out cheaper than ordering directly from ECS and having to pay shipping + taxes
    V6_Man, GarethS4 and xpoweruk like this.
  40. V6_Man
    6,910
    13,947
    Cheers @Lavis89. Email sent, will give them a call first thing tomorrow as well
    It is time to start ordering and get things in place and I hope to have all mods done in next couple of months. Still to go:
    - Milltek Race Resonated (can't afford Valvesonic for next 4-5 months and I want an Exhaust asap ). Ordering tomorrow.
    - Rear Sway Bar
    - Eibach Pro Kit (or KW)
    - Charger-cooler
  41. Lavis89
    2,039
    822
    I like the milltek personally, there is a little bit of drone but I've never regretted buying it, it's only over a small part of the rev range.
  42. Cerbera9
    430
    305
    I'd be interested to know how much difference changing the rear sway bar makes? The only people I've found so far that just sell a single rear sway bar are Awesome GTI who sell the 034 Motosport one but also I've considered the H&R front and rear kit but not bit the bullet yet.
  43. xpoweruk
    2,436
    1,768
    With sports diff do both
    Without do just rear
    V6_Man likes this.
