Ticking/Tapping
Pro-cookie Oct 9, 2018
  1. Pro-cookie
    Pro-cookie Member Audi A4 Audi Avant Owner Group
    225
    Hi guys.
    1.8 SE AVV engine code, I have a tappety/Ticking sound coming from under the black intake manifold toward the front of engine on right hand side as you look at it, it increases with engine revs. I have no management light on and doesn’t,t appear to affect what little performance it has lol.
    Does anyone have an idea what this could be? And is it something I should be worried about?
    Thanks in advance guys.
  2. Avatar
    Google AdSense Advertisement
  3. russell.hammond
    russell.hammond New Member
    21
    Could it be cam belt tensioner?
  4. Leo Komninos
    Leo Komninos Member
    96
    22
    Pcv valve, or system.
    Sent from my G3121 using Tapatalk
  5. Pro-cookie
    225
    I did the cam belt and tensioner about 5000 miles ago also it sounds like it’s above and behind that. I must admit Leo I thought for a while it was blowing a little harder than normal through the rocker which would suggest it could be the pcv valve.
  6. Pro-cookie
    225
    Next question is how easy is it to replace one and what does it look like lol.
  7. Leo Komninos
    Leo Komninos Member
    96
    22
    You'll have to investigate. Trace pipes and check. Heard some people use a spray and check for idle change. But can't recall what type of spray. Guessing as going into intake could just get away with water.
    Personally I would just get a catch can and remove the pcv system. Bl**dy coats everything in oil.
  8. Pro-cookie
    225
    I have got lots of random oil leaks five in total from bizarre areas so I’m guessing then that it must be pcv blocked hence things as you say are coated in a film of the stuff. I’ll have to look into how to fit a catch can then as I’ve never had one or done it lol. It might also look odd as it’s a non turbo basic engine people might think I’m trying to make it something it’s not
  9. Leo Komninos
    Leo Komninos Member
    96
    22
    I'm new to catch cans too. But have been advised to delete pcv system on 2.7 biturbo, as intercooler hoses can have so much oil you can pour it out. Also have a 2.4 v6 and thinking of doing same as, smell oil in car after short trips. After my research, usually involves removing all pcv system, plugging pipes and maybe a ecu software mod to stop a check engine light.
  10. Lowfield
    Lowfield Member
    85
    17
    By 2.7 pcv system do you mean spider hose and pcv?
    I bought the lot new from tps recently (6 months back) for a very reasonable £120.
    Who told you to delete out of interest?
  11. Leo Komninos
    Leo Komninos Member
    96
    22
    Researched oil catch cans, and Justin balou on YouTube, most people say the lower IC hoses fill with oil. Only reason they did not fit from factory, was (IMHO) emissions and expecting the end user to empty regularly.
    Please tell me if I am wrong.
  12. Avatar
  13. Leo Komninos
    Leo Komninos Member
    96
    22
  14. matt66604
    matt66604 Active Member VCDS Map User
    227
    27
    I’ve had similar issues before with Pcv check valves on the AEB. Blew oil out of every possible orifice. Boost pressure entering PCV and made a clicking-tapping under load.
  15. matt66604
    227
    27
    Also had a non turbo 1.8 and that one clicked and was tappety. And oil pressure warning light didn’t come on but not surprisingly the oil pump pickup was blocked. I’d check that out first if it’s not been done before.
  16. Pro-cookie
    225
    Ok is it easy enough to do? I’m assuming the sump off once I have a replacement gasket for it, but does the pick up come off easily? It’s AVV engine code.
  17. matt66604
    227
    27
    To get the sump off you either have to slacken engine mounts and jack up so sump will clear subframe enough. Or I normally take all bolts out of sump then get various 1/4” drive extensions between the gap of sump and block and unbolt the pickup pipe. The engine still needs jacked up though with this method. But not as much.
  18. matt66604
    227
    27
    It’s normally just sealer on those also. No gasket.
  19. Pro-cookie
    225
    Ok thanks mate, don’t suppose you know the size of the sump plug do you? I’m going to replace mine and the seal.
  20. matt66604
    227
    27
    Depends which sump plug you have. New style is 19mm , new sump plug comes with the seal. The old school sump plug is 17mm if I remember correctly. And that one has the replaceable massive copper washer
  21. Pro-cookie
    225
    AVV Engine code it’s a 2000 so more likely to be the old one then. Cheers buddy :thumbs up:
