Thoughts on Road Tyre's makes and models ? been running on Nankang ns2r this year noisy , primeval , but effective.. Old question, any new options worth a look ? Tnx -G
PS4 all day my bro in law had them on the tt loved em, I run ns2r but don’t use the car daily only track days and the odd blast not fantastic in the cold/winter are they Sent from my iPhone using Tapatalk
Allays used continentals sports contact , the ns2r came 'new' with a set of wheels , much more grip than the Cont .. wet / cold , may be less , still driving 40 mile round trips , A.& M way , wet / salt seems predicable just need to press on with them -) yes big change wet/dry , probably more noticeable with the enhanced dry grip ? Primeval , probably the best description , ns2r, loud rumble , one post complains of changing wheel bearings ..I had the same thoughts , very little bump softening , as the video says, hard heavy steering , and with the cut pattern no block shuffle catch 22 , smooth and ooze , or bumpy and rash sense would put ps4 on the 17 winter and nsr2 on the 18 summer ?
I thought this too with the wheel bearing comment they just need to be swapped front and back I think, sounds like a logical idea Sent from my iPhone using Tapatalk
Had mine on the ramps, checking the bearings , the vibration is quite pronounced , but, pretty impressive performance , with no tread blocks , just the cut pattern and heavy side walls , the steering is precise , with the car set -25mm koni coilovers , its not really set up for a smooth ride , with the re-map, actually is quite lively , standard power level was a touch under par for the grip , gave a very 'stuck' feel
