Laszlo@034
Introductory Special: ACTIVE
We're pleased to announce an exclusive Introductory Special on a line of all-new B8/B8.5 Audi A5/S5 Drivetrain & Chassis Upgrades by 034Motorsport! These performance parts are in-stock and ready to ship.
034Motorsport Drivetrain Mount Insert Package, B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5 Billet Aluminum
Retail: $255.00 + Shipping
Introductory Special: $225.00 + Shipping
(Individual inserts are available separately below.)
Introductory special pricing is available through June 20th. Thank you for all of the interest, and we hope you enjoy this new line of performance upgrades for your Audi!
034Motorsport is proud to offer our Billet Aluminum Drivetrain Mount Insert Package for the B8 Audi A4/S4/RS4, A5/S5/RS5, and Q5/SQ5! The factory Audi transmission and rear differential mounts have large voids in the rubber damping medium, which results in excessive drivetrain movement under load. This movement results in slop than can be observed when accelerating, decelerating, shifting, and launching.
These billet aluminum inserts are designed to fill the large voids in the factory transmission and rear differential mounts, and limit drivetrain movement without sacrificing ride quality or introducing any additional noise, vibration, or harshness into the cabin. By filling the voids in the factory mounts, this package eliminates the associated slop to ensure that you experience crisper shifts, harder launches, and a smoother driving experience.
This mount insert package was thoroughly tested by 034Motorsport, JH Motorsports, and independent Audi enthusiasts before release. Installation is very simple, can be performed in minutes, and is completely reversible.
Features:
- T6-6061 Billet Aluminum Construction
- CNC-Machined In-House
- Clear Anodized Finish for Durability
- Engineered to Fill Voids In Factory Transmission/Differential Mounts
- Drastically Reduces Transmission & Differential Movement During Shifting & Deceleration
- Improves Shifting Feel, Resulting in Crisper Shifts
- Allows for Harder Launches & Better Response from Rear Differential
- Will Not Cause Additional NVH Transfer Inside Cabin
- Easy, Straightforward Installation Takes Minutes!
- 034Motorsport Billet Aluminum Transmission Mount Insert
- 034Motorsport Billet Aluminum Rear Differential Mount Insert Pair (Front) - New Product!
- 034Motorsport Billet Aluminum Rear Differential Carrier Mount Insert Pair (Rear) - New Product!
- Transmission Mount Insert: Web - PDF
- Rear Differential Mount Insert (Front): Web - PDF
- Rear Differential Carrier Mount Insert (Rear): Web - PDF
- 2009 - Present Audi A4 (B8/B8.5) - Quattro Models Only
- 2010 - Present Audi S4 (B8/B8.5)
- 2013 - Present Audi RS4 (B8/B8.5)
- 2008 - Present Audi A5 (B8/B8.5) - Quattro Models Only
- 2008 - Present Audi S5 (B8/B8.5)
- 2013 - Present Audi RS5 (B8/B8.5)
- 2008 - Present Audi Q5/SQ5 (B8/B8.5)
- 2010 - Present Audi A8 (D4) - Quattro Models Only
- 2012 - Present Audi S8 (D4)
034Motorsport Rear Differential Carrier Mount Insert Kit, B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5
Retail: $95.00 + Shipping
Introductory Special: $85.00 + Shipping
034Motorsport Rear Differential (Front) Mount Upgrade Kit, B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5
Retail: $85.00 + Shipping
Introductory Special: $78.00 + Shipping
034Motorsport X-Brace Billet Aluminum Chassis Reinforcement, B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5
Retail: $495.00 + Shipping
Introductory Special: $445.00 + Shipping
034Motorsport is proud to offer our Billet Aluminum X-Brace Chassis Reinforcement Upgrade for the B8 & B8.5 Audi A4/S4/RS4, A5/S5/RS5, and Q5/SQ5! The factory Audi front subframe brace is manufactured from multiple pieces of stamped steel, and allows for performance-hindering chassis flex under load. This torsional flex can result in improper suspension geometry and alignment when cornering, and leads to vague steering feel and lack of steering precision.
The 034Motorsport X-Brace is a billet aluminum chassis reinforcement to replace the factory front subframe brace to increase torsional rigidity, resulting in improved steering feel and handling performance. Machined in-house from T6-6061 billet aluminum, the 034Motorsport X-Brace is engineered to outperform the stock welded, stamped steel part and ensure that suspension geometry is not compromised by chassis flex under hard cornering.
This chassis brace upgrade was thoroughly tested by 034Motorsport and independent Audi enthusiasts before release. Installation is very simple, can be performed in minutes, and is completely reversible.
Features:
- Engineered to Replace Factory Front Subframe Brace
- Drastically Reduces Chassis Flex When Cornering
- Enhances Handling Dynamics and Performance
- Improves Steering Feel, Consistency, and Precision
- Modular Design Fits Both B8 (Pre-Facelift) & B8.5 (Facelift) Models
- Easy, Straightforward Installation!
- 034Motorsport Billet Aluminum X-Brace Chassis Reinforcement (Fits B8/B8.5 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5)
- Modular X-Brace Inserts (Set of 2)
- M10 X-Brace Assembly Screws (Set of 4)
- M5 Undercarriage Tray Mounting Screws (Set of 4)
- 15mm Undercarriage Tray Mounting Washers (Set of 4)
- Web - PDF
- Product Information Sheet
- 2009 - Present Audi A4 (B8/B8.5) - All LHD Models
- 2010 - Present Audi S4 (B8/B8.5) - All LHD Models
- 2013 - Present Audi RS4 (B8/B8.5) - All LHD Models
- 2008 - Present Audi A5 (B8/B8.5) - All LHD Models Except Cabriolet
- 2008 - Present Audi S5 (B8/B8.5) - All LHD Models Except Cabriolet
- 2013 - Present Audi RS5 (B8/B8.5)- All LHD Models Except Cabriolet
- 2008 - Present Audi Q5/SQ5 (B8/B8.5) - All LHD Models
- 8T1 399 345J / 8T1399345J
- 8K1 399 345E / 8K1399345E
- Fits LHD (Left-Hand-Drive) Vehicles Only. Does Not Fit RHD (Right-Hand-Drive) Vehicles.
- Does Not Fit Cabriolet.
- We recommend using new factory stretch bolts to install the X-Brace. Complete factory bolt kits are sold separately below.
- B8 (Pre-Facelift) X-Brace Bolt Kit
- B8.5 (Facelift) X-Brace Bolt Kit
Click Here to Order Full Drivetrain Insert Package!
Click Here to Order Rear Differential Carrier Mount Insert Pair
Click Here to Order Rear Differential (Front) Mount Insert Pair - Please Note: This product will replace any existing polyurethane insert upgrade, if you already have one installed.
Click Here to Order Transmission Mount Insert
Click Here to Order X-Brace
