  2. Dismiss Notice
The Haunted Gear Stick!
tyson Jun 22, 2017
  1. tyson
    tyson Member
    130
    I am having issues with the gearstick. It's an odd one but intermittent.
    Sometimes the gearstick will stick left and right, but sometimes it's perfect.
    I've had the gaitor off taken the mechanism apart re-greased and still the same...
    Anyone else had this or have any ideas?
  2. Avatar
    snack-media
    Advertisement
  3. snowy
    snowy Active Member
    443
    110
    43
    Check cables, cable bushes, selector mechanism on top of gearbox
  4. tyson
    tyson Member
    130
    I've greased everything.
    It seems to happen once the car is up to temperature.
  5. Prawn
    12,096
    4,331
    The issue is the small plastic 2 part bush that sits on top of the shift tower on the gearbox end.
    It's usually caused by moisture getting inside the bush and causing corrosion. It happened on my wifes golf and got really bad.
    You need to replace the bush, and really thoroughly clean out the housing using sand paper too.
    tyson likes this.
  6. Erikn89nl
    Erikn89nl Well-Known Member
    951
    388
  7. tyson
    tyson Member
    130
    Thanks for the help, seems to have done the trick.
