I've never noticed a beep.
I might be deaf !!
What beep is this? Is there also a visual display message?. If so my car does not do it at all.
What?! Maybe it's me then, I forgot to mention I sometimes hear voices in my head.
But seriously, it's strange that not all cars has the same beep then.
Am I the only one or is someone else having the same issue?
As I recall it beeps before you even start the car - as soon as you turn the ignition on for me. Mind you, I have a delay from ignition on to start up to disable the Ghost.Well I’ve never ever had that message since having my car. My car is a daily with early starts too.
Am thinking the same, or a “parameter”. I need to get some time with a FL vehicle in order to bottom it out really.Yeah I had a good look the other evening however nothing jumped out in VCDS or VCP to be honest.
I’ve a feeling it’s a firmware embedded thing.
When you get time can you get back to me for the quote to have TPMS fitted to my 2018 RS3 PleaseAm thinking the same, or a “parameter”. I need to get some time with a FL vehicle in order to bottom it out really.
Yes it can be retrofit and I will be replying to parts and retrofit enquiries starting tomorrow... I hope. My parts guy has been away sick for a few daysCan this be done? I really wanted it but as I specced my car early on most of use will know ****** Audi did not have it added in the configurator
Hi there.
I just signed up to this forum as I often was a quiet reader. I'm very active in the german coding community and also in the Ross-Tech Forums.
I own myself a MY18 Audi RS3 Facelift and also did some deep investigations regarding the cold start warning.
Without success so far.
But.
On my request there was a label file delivered with VCDS 18.2.1 for the DAZA engine.
There are two bits which are not documented so far. Byte 8 Bit 1 and Bit 2.
I did not have the guts so far to try this it if it has anything to the with the cold start warning.
Anyone wants to try?
I'm lacking the pioneer spirit at this point and I do not have the capability of resetting my car via ODIS/SVM if anything gets screwed up.
If no one ever tried undocumented bits, we would still be in coding stone age.
I didn't start this thread about how to deactivate this
Should I say nothing instead of sharing what I know? Why so offending?
Dear Sir,
I've spent hours in searching for that special deactivation bit or adaptation channel in order to deactivate this cold start warning.
The intention of my post is like "stop searching anywhere, it is not there (documented!!)".
I agree with your concerns but like I know the common coding community, one will be thankful for any hint no matter whether it is undocumented bits in the ECU.
My understanding of your way of responding is that you might not be used to common coding chit chat and pioneer thinking.
I'm pretty sure there are several people out there who already did some ecu map tuning. As the factory guarantee has then vanished anyway, one or two bits won't hurt![]()
Dear Sir,
It’s one thing to be able to change a setting and test but it’s another to be able to put it back / reverse the change. I would not recommend messing about with the coding unless you have access to tools which can reverse any changes. If someone wants to pop over to see me I can always SVM the car back to life should anything go wrong.
Btw hadez16 T-800 works with me and both of us have very extensive coding experience![]()
DjAlix,
I'm aware of your experience.
I just did a bit of exaggeration as T-800 sounded like "One does not simply speak about undocumented bits. Save the children first. Set him on fire!!11"
I joined this (for me) wild area non-german forum to help and contribute, not willing to break someone's car.
