R
RC944
Guest
so a few weeks back i had a nice message on the obd reading something along the lines of 'battery flat will charge when the engine is on...'
typical flat battery symptoms at this point including leaving home lights not coming on when unlocking etc
plugged in the vcds and yes i have a bunch of address 61 battery reg codes Quiescent Current Stage 1-6 (this fault code keeps popping up despite numerous clear downs)
so, i then start trying to figure out whats going on ie dying battery vs drain
all electrics are customarily switched off before the vehicle is locked
the battery is a varta that i am told is no more than 3 years old. its the correct spec for the model - s5 010
https://www.tayna.co.uk/S5-010-Bosch-Car-Battery-Type-110-S5010-P9706.html
the battery is reporting about 11.7v across the poles after its been out for a spin... the alternator is working fine
ive had it on an overnight trickle and it still was not showing anything close to 12 after about 12 hours of charge
ive use put a sealey battery tester to test under load and its about 11.7 under load and 12.2 across the poles no load (why its so different to the multimeter i know)
i will today use my newly delivered hydrometer to check the cells and hopefully establish whether the battery is borked or there is a persistent drain
i have not plugged in vcds to run diags on the battery control module. i can see that there is a TSB for a software upgrade (i have MMI high) and throught hte vcds
so in terms of next steps
- check cell gravity with new hydrometer
- if above is borked get new battery
- if above fine then seek out drain
should i in any event seek to install the software update so the radio does go into sleep mode properly?
thanks in advance
thanks in advance
