Hi all,
Just wanted to know if all of the B7 TFSi engines have the chain driven balance shaft/oil pump combo like the TDi engines or if some are gear driven? Getting slightly concerned about getting a B7 TFSi as the project car owing to the failure rates of the sprockets, balance shafts and oil pump hex drives. It seems that VAG don't seem to do well with oil systems considering the 1.8T sludges up and the 2.0 TFSi seems to have failing pumps and chains etc.
Also, if no engine has the gear driven oil pump system is there a way to retrofit the later gear driven setups to an earlier engine? Is there a list of the engines that are most commonly affected with this issue?
