  2. Dismiss Notice
Testing antenna via VCDS?
HertS3 Aug 28, 2020
  1. HertS3
    HertS3 Registered User
    1,106
    342
    Hey all,
    Having just been away, it reminded me that my radio signal doesn't quite seem right. OK I was out in the sticks a little (Somerset/Devon) but I didn't even seem to pick up stations like Radio 1 which should have pretty widespread distribution. Also when I'm driving around my local area the radio will sometimes cut out for a couple of seconds and then come back, I don't recall this happening on my previous S3.
    So my question is whether it's possible to run an extended antenna/radio test on VCDS to check that everything's OK? I've checked for codes and have nothing.
    Updated my MMI to the latest available software for my car (B8.5 MMI 3G high/tech pack) and did a custom install and specifically selected the radio modules so hopefully that's not the cause of the issue (updated very shortly after getting the car so can't confirm if the issue was there before the updates unfortunately)
  2. Avatar
    snack-media
    Advertisement
  3. Stonefish
    Stonefish Registered User
    251
    69
    I think if you use the Green Engineering menu there is a bit that gives you signal strengths for different radio channels. I used it a few years back when my DAB went crappy.
  4. HertS3
    1,106
    342
    Thanks, will have a tinker
  5. rum4mo
    rum4mo Registered User
    2,192
    557
    Halfords used to sell a cheap DAB aerial, I used one of them to find out if my used DAB Concert radio worked okay when I swopped it from a non DAB Concert radio, I did not even need to connect it to the car's 12V supply, that would give you a quick indication if it was your car's inbuilt DAB aerial amp that was the problem. I tend to live in a "poor" area for some DAB signals, especially local or regional stations - it seems in UK we are treated like a communist state when it comes to DAB radio signals, ie the major London bases radio station signals get pumped out at high levels and regional and local stations suffer.
  6. HertS3
    1,106
    342
    I'm wondering whether the roof bars and bike carriers (one being directly above the antenna) would have any bearing on the signal received. I'll be able to test this today as I've removed them and going on a long drive, see if it's any better.
  7. HertS3
    1,106
    342
    I think it's the stations, put on BBC Radio 2/6 and all down M25 / M4 it was fine
  8. rafletcher
    rafletcher Registered User
    350
    As to DAB antenna, I think it’s actually in the rear quarterlight windows in an Avant. The roof aerial is for the phone I believe.
  9. Stonefish
    251
    69
    Have you tried a re-tune?
  10. HertS3
    1,106
    342
    I didn't but I assume the car did it itself as lots of stations disappeared when I was further out in the sticks, towards Devon. Just been around Somerset / Wiltshire and it was fine with Radio 2, I think stations like Magic Musicals struggle further out
  11. Stonefish
    251
    69
    I don't think they are clever enough to re-tune. Also there is an option that the radio will switch to FM if the DAB signal is not very good. In the case of BBC Radio 2 etc this switch is quite seamless.
  12. Avatar
    snack-media
    Advertisement
  13. HertS3
    1,106
    342
    Yes, I have that option selected
  14. JohnS3
    JohnS3 Registered User
    3,174
    45
    You can check the status of the TV antenna amplifiers with VCDS using the extended tests. As the TV antenna amplifiers (well 2 of them) are also radio antennas it makes sense that you can do similar tests via 56 radio. Can’t check right now but will have a look in the coming week.
    HertS3 likes this.
