  2. Dismiss Notice
Terraclean done but still overboost fault
CarbonMike Apr 16, 2016
  1. CarbonMike
    CarbonMike Registered User
    446
    187
    43
    Had a terraclean done today in attempt to cure an overboost issue on a 2.0 TDi BRE engine, had a mityvac on the actuator an all seems good there and also the vac diaphragm seems all good. Had a diagnostic check on the car before & after an all was good there also.
    Now overboost occurs around 3200 revs or nearing a 3 figure speed but I get no flashing coil lights when this happens. Used to occur around 85mph on lower rpms.
    Any idea's anybody?
    On a plus side though, the terraclean guy said mine already had a dpf delete, so its probably had a remap too!
  2. Avatar
    snack-media
    Advertisement
  3. tony mc
    tony mc Registered User
    1,124
    645
    my cars the same as yours mate, the only thing that fixed it when i was getting overboost issues was taking the turbo out and reconing it. also mine came from the factory without dpf i thought the bre 140 never had dpf ???
  4. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Registered User
    2,015
    133
    Good question ' how did he know it had a DPF delete' I'm alittle skeptable about terra clean personally,
  5. tony mc
    1,124
    645
    i had it done both turbo/egr system and engine, car felt a little better but not worth the coin if you ask me
  6. CarbonMike
    446
    187
    43
    He was on about some sensor on the dpf can/cyclinder been removed or something along them lines.
    Im not overly sure really, not up on diesel engines.... on a petrol inline, boxer or V8 i can fix or rebuild anything, diesel is not fortè!
  7. tony mc
    1,124
    645
    the cat dos'nt have any sensors in it mate i took mine out, there's no lambda's on it or anything just a big pipe really with the catalyst in it
