  2. Dismiss Notice
Temp Gauge intermittent, incorrect readings
Dan11 May 17, 2015
  1. Dan11
    Dan11 Registered User
    274
    Hi,
    hopefully someone can help as i have tried searching and can't quite find what i am looking for. i am unsure if i am searching for the right thing or using the right words, but hopefully my description will help!
    Car: a4 avant b6 1.8T bex engine.
    my temp gauge has been intermittent the last few months. i will be driving along and it will slowly raise to around 70 degrees, then drop back to 50. after a few more miles it will raise to 90 and stay at 90.
    i have checked to see if my engine is heating up correctly, and can confirm after using a diagnostics tool, that the engine does warm up, and it is intact the gauge not showing the correct temperature. this would leave me to believe that it is not a fault within in the engine, but rather wiring/instrument cluster/ecu?
    Can anyone shed any light on this? any tips on what to check? or if anyone has experienced similar problems?
    If someone could let me know that would be great!
    [​IMG]DSC_0428
    Dan
  2. Avatar
    snack-media
    Advertisement
  3. Ro55
    Ro55 Active Member VCDS Map User
    870
    128
    43
    Common issue. new sensor or stat. what diagnostics did you use?
    Do a search on here and you will find lots of info.
    Nice motor.are those A3 speedlines? 18'a? spacers?
  4. Ro55
    870
    128
    43
  5. Dan11
    274
    Thanks for the link, I had disregarded that sensor as I thought that would not allow a diagnostics tool to read the engine temp correctly at all?
    Is that sensor likely to cause the gauge to not read correctly even when the ecu reads the engine temp correctly? I hope that makes sense?
    They are also speedlines from an a5. 19x9j et33. Proper tight squeeze to get the car that low with the 255 tyres on...
  6. Ro55
    870
    128
    43
    How do you know the ecu is correct if the sensor is faulty?
    what diagnostic tool you using?
    From the above description its a classic temp and stat situation.cheap easy to do.
    has it been P00 on fuel lately?
    you need 235 35 19 tyres
  7. Dan11
    274
    Thinking about it, it has been rubbish on fuel recently. Best go to the dealers and get a sensor then!
    255s fit now rolled the rear arches out a bit and removed the liner screws from the front and it now
    Only rubs on the front over big bumps.
  8. Wastegate86
    Wastegate86 Registered User
    19
    Sounds like thermostat to me
    It's recommended to replace them every 4/5 years along with the cambelt but most don't bother
  9. Ro55
    870
    128
    43
    Normally if the sensors at fault it will move irratically and fluctuate.
    Ive just had problems after a new stat and sensor,turned out the plastic housings locating lugs had broken and stuck in the stat.
    Check this also :)
  10. Dan11
    274
    Fitted new sensor. Problem solved.. Although it took me three go's to get the right sensor!!!!
  11. Ro55
    870
    128
    43
    Was the correct one green?
