Tdi injectors moving
kevsmith
Right who can help I have a A4 2.0 tdi abvand 170 quattro, I have had an injector weeping so had a look today and all the injectors are moving in there clamps? Is this normal? Or am I right in thinking new copper washers will rectify this the clamps are tightened down its the injectors that are moving thanks
You are right. That is not normal. Are the nuts/bolts holding the clamps loose or tight? If it's loose - self explanatory. If it's tight, it'd be worth taking them out and checking how well it seats, check copper washers, etc. Probably a penny for the appropriate copper washer, so if you're feeling like replacing them anyway, at least it's not the most expensive investment.
